Turn off backup camera? Tailgate delete questions.
Old Dec 17, 2020 | 07:02 AM
mxzeatr's Avatar
mxzeatr
My 2020 is a plow truck. I remove the gate for the winter for better visibility. My 17 didn't have a camera, so it was fine. But when I ordered my 20 I wanted sync etc so it has the camera. With the tailgate off I get a bright blue screen and a message saying 'contact dealer'. Which isn't a huge deal, except it happens hundreds of times a day and it gets annoying, and the bright blue screen sucks.
Can I shut it off? Any other options?
Thanks!
Old Dec 17, 2020 | 08:12 AM
kehinnc's Avatar
kehinnc
Did you install the cable caps? This text is from page 72 of the 2020 Owners manual.
"You can remove the tailgate for more loading room.
1. Obtain the tailgate removal kit from the glove box.
2. Locate and disconnect the frame connections. They are on the left-hand side of the vehicle.
Note: Your vehicle may have up to three frame connections.
3. Install the caps from the tailgate removal kit on the in-line connectors that remain on the vehicle.
Note: If you do not install the caps on the connectors, some features may not operate as intended."
Old Dec 17, 2020 | 08:39 AM
mxzeatr's Avatar
mxzeatr
Of course I have the tailgate delete plugs installed. But that is all they are, simple blank plugs. There's nothing in them to tell the truck the tailgate/camera is rightfully gone. The truck senses there's no signal from the camera and puts the contact your dealer message up every single time you hit reverse.
Kindof silly if you ask me, and the bright blue screen is maddening after many hours of it popping up.
I'm looking for an aftermarket camera with this connection on it now, even if it's snow covered I won't have to push ok to the contact dealer message to adjust my radio settings all the time.
Any suggestions on brands would be great!
Old Dec 17, 2020 | 08:59 AM
ZooDad's Avatar
ZooDad
Retired guy fixn stuff
You may be able to disable the camera using ForScan
Sent you anPM
ZooDad
Old Dec 17, 2020 | 09:10 AM
mxzeatr's Avatar
mxzeatr
Sent you anPM
ZooDad
That would be awesome! Thank you! PM replied to!
Old Dec 17, 2020 | 03:02 PM
_hedge_'s Avatar
_hedge_
That's weird. I have a truck camper so I take my tailgate off a lot and never had any issues with the cameras. Mine has the 360 cameras but it just shows black in that section when it tries to stitch them together.
Old Dec 17, 2020 | 04:21 PM
stangman68inftc's Avatar
stangman68inftc
Another option would be to relocate the camera. I have a tommy lift installed and relocated the camera from the factory tailgate to the lower part of my tommy lift.
Old Dec 17, 2020 | 04:29 PM
mxzeatr's Avatar
mxzeatr
I only have the rear view camera so I don't get any other option.
I'd have to disassemble the factory trim each time I take the gate on and off. I run the gate 9 months a year easy, and enjoy the cameras full functionality then.
Old Dec 17, 2020 | 04:30 PM
mxzeatr's Avatar
mxzeatr
Sent you anPM
ZooDad
Huge thanks to ZooDad!
One key stroke and the camera is off, then back on using foracan!
Old Dec 17, 2020 | 05:00 PM
stangman68inftc
I wonder how much it would be to buy a 2nd camera so that you could leave the original in the tailgate. Might even be able to get a used camera and wiring at this point. Just a thought.
Old Dec 17, 2020 | 06:12 PM
wizardsr's Avatar
wizardsr
$250 for non-heated, $280 for heated. I bought one from camera source and mounted it on my spreader. It's plug & play, and works exactly like the tailgate camera, only on my salt spreader. https://camerasource.com/super-duty-...grade-cam.html
Old Dec 17, 2020 | 06:31 PM
kehinnc's Avatar
kehinnc
Do the guidelines also appear when this camera is in use?
This would work on a 5th wheel tailgate also. Good solution.
Thanks
Old Dec 17, 2020 | 06:55 PM
mxzeatr's Avatar
mxzeatr
Here is the info for forscan users if interested.
first back up the APIM module
then go to AsBuilt and change
(APIM) 7D0-01-01 220A 0006 00xx
to
7D0-01-01 200A 0006 00xx
Old Dec 18, 2020 | 01:42 PM
wizardsr's Avatar
wizardsr
Thanks
No guidelines on the aftermarket camera. But in other ways it's better than factory as it has infrared LED's (night vision in pitch black) and heated lens. They have many other mount types, flush mount, hard mounts for high up on a utility body, etc, and they plug in to the same plug as the factory camera. Very happy with mine so far!
Only wish I had known about these before I ordered my F550 a year ago, as I ordered the factory camera ($400+ option) and it's super cheap, these are far superior!
Old Dec 20, 2020 | 07:47 AM
tjeeper's Avatar
tjeeper
I bought an aftermarket camera, one that attaches to the license plate. Had this on my 2015 F250. For my new 2021 F350, I had to get a new cable as the connector changed (of course). I bought the cable from an ebay seller. Took me about 15 min to rewire the camera to the new cable/plug, and 10 min to install. Works same as it did on my F250. I took off the tailgate right away, since I haul a truck camper.
Justvisiting1
Oct 28, 2021 09:39 AM
eyoung14
Apr 8, 2020 08:11 PM
thecause17
Aftermarket Products
Mar 10, 2018 06:36 AM
2civicrr
6.7L Power Stroke Diesel
21
Jun 6, 2015 08:42 PM
6t6merc
Nov 12, 2013 07:20 AM
