snugtop outback canopy interface with ford camera system
What i was thinking about doing was removing the factory camera and wiring from the tailgate and mounting it as close to its original location on the new rear canopy door. My hope is to get back to a stock camera configuration. any thoughts on this? do you see any major roadblocks? thanks in advance.
seriously..I have the same problem with my ARE Z seties cap....I was thinking about doing something simular....havent found a solution yet.
You can easily remove the rear OEM camera from your tailgate in about 5 minutes.
Here is a video:
Buy this relocation housing for the camera and mount it just above the handle on the rear door, so it is in the same location as it was in the tailgate.
https://rostra.com/ford-superduty-36...relocation.php
https://www.mnrelectronics.com/250-8...ation-housing/
If your camera has some fogging, then buy this kit which includes a new OE Ford camera with the housing: https://www.mnrelectronics.com/250-8...y-ford-camera/
Using the OEM camera, and having it back in its original position, your 360 camera and all trailering functions should work again!!
