Transmission identification
Old Dec 15, 2020 | 04:59 PM
Grendel's_virtue's Avatar
Grendel's_virtue
Trailering
I'm looking to bid on a salvage truck for parts, but I really want the zf 5 speed trans. Is there a way to identify which trans the vehicle has by vin or door sticker?
Thanks,
Johnny
Old Dec 15, 2020 | 05:24 PM
Conanski's Avatar
Conanski
If you find a '90s vintage heavy duty F250 or F350(8500 gvwr or higher) with a manual trans it has a ZF. And on the door pillar decal you should find a corresponding code for it..
The ZF5 is physically bigger than the M5OD and has more ribs on the case, and look for the PTO cover plate on the drivers side.. the M5 doesn't have this at all.
And also note that because the belhousing is integrated you need to find a big block or small block version to match whatever engine you want to bolt this up to.
Old Dec 16, 2020 | 08:48 AM
Grendel's_virtue
Trailering
Thank you Conan,
The sticker for the 1991 f150 has the code M on the door which tells me that it's the mazda 5 speed. Is this a decent transmission?
Thanks
Old Dec 16, 2020 | 08:49 AM
jas88's Avatar
jas88
Of course it's decent, but it is not as heavy-duty as the ZF and lacks the granny low gear that the ZF has.
Old Dec 16, 2020 | 10:34 AM
Mikulh's Avatar
Mikulh
A lot of people talk down about the M5OD, and I have no doubt that it's not as strong as a ZF5, but my M5OD has served me well for over 265,000 miles so far and is still going strong... and I haven't babied it.
Having said that I only tow occasionally. If you tow often the ZF5 is probably a better way to go.
Old Dec 16, 2020 | 03:31 PM
torq'ta 5 8's Avatar
torq'ta 5 8
If your going to tow, look at 250/350 they came with ZF manuals
Old Dec 16, 2020 | 03:38 PM
Grendel's_virtue
Trailering
I'm going to hunt for one. It looks like the swap from NP435 to ZF will not be easy.
waltmm
Feb 23, 2020 08:08 PM
Mike Hale1
20
Aug 5, 2019 04:00 PM
mt_wallet
Nov 1, 2016 08:26 PM
Lug Nut
Aug 30, 2012 10:29 AM
'77 F-250 Camper
18
Apr 30, 2011 08:07 AM
