1990 E150 Parklane Conversion
Old Jan 8, 2021 | 10:35 PM
annaleigh's Avatar
annaleigh
Here's something to help you out when you start cleaning the selector valve. None of the videos I have seen tell you how the valve really works.
Old Jan 16, 2021 | 03:53 PM
Mike1's Avatar
Mike1
So I finally got around to digging my OBD I code reader out, KOEO codes are 26 / 63 / 85 KOER codes are 98 / 63, The 98 is the one I hope is on because of the other ones, if not there may be a problem with the transmission. Anyway, to cold to mess with it now, wait til warmer weather.
Old Jan 16, 2021 | 08:22 PM
Ketch347's Avatar
Ketch347
Thanks for the news.
Please would you explain what are KOEO & KOER ? Also with witch code reader you working ? Thanks
Old Jan 16, 2021 | 09:35 PM
Mike1's Avatar
Mike1
Key on engine off / key on engine run
using an Equus 3007 OBD I tester
Old Jan 17, 2021 | 03:34 AM
Ketch347's Avatar
Ketch347
Thank you for your quick answer
Old Mar 8, 2021 | 08:02 AM
Mike1's Avatar
Mike1
Never Mind making new post.
annaleigh
Apr 24, 2016 08:01 AM
syver
Projects
Nov 23, 2012 04:52 PM
FORD E-150
Mar 8, 2009 10:29 AM
withgusto
Sep 5, 2002 08:11 AM
