Manual Transfer Case Removal
Old Dec 15, 2020 | 06:44 AM
Walleye Hunter's Avatar
Walleye Hunter
OK, I looked through tech folders and didn't find anything on it so forgive me if it was right under my nose and I couldn't see it...I'm trying to get the manual transfer case out of a truck and don't know the procedure. I'm having trouble getting the plastic piece off from around the selector lever and I'll soon just destroy it with a pry bar if I have to but I would prefer to save it if I can. I don't think I need a detailed run-down but the basics should get me going in the right direction.
Thanks.
Old Dec 15, 2020 | 06:56 AM
FordTruckNoob's Avatar
FordTruckNoob
Here's the procedure. The closest my manual gets to an E99 is the 2000MY. The In-Vehicle Repair section shows how to remove the lever.
Tagging @Y2KW57 for Tech Folder content. (Done)
Last edited by Y2KW57; Dec 15, 2020 at 04:40 PM. Reason: to indicate inclusion of the attached documents into the Tech Folder as requested.
Old Dec 15, 2020 | 07:04 AM
Walleye Hunter
Good, that stick doesn't even need to come out then, just disconnect it down under.
Thanks
Old Dec 15, 2020 | 07:32 AM
SkySkiJason's Avatar
SkySkiJason
Thanks
Yes, after unhooking the shifter and bracket/rods, the driveshafts and (6) 13mm bolts hold the t-case to the trans. You’ll want a new gasket to go back in there.
Why are you removing t-case?
Old Dec 15, 2020 | 10:40 AM
Walleye Hunter
Oh boy, somebody just had to ask...this is in a parts truck I bought a couple of years ago and I've been taking things off of it a little at a time and now I'm at the trans and transfer case.
Old Dec 16, 2020 | 12:46 PM
JayTheCPA's Avatar
JayTheCPA
Pictures always help
Old Dec 16, 2020 | 12:49 PM
ford390gashog's Avatar
ford390gashog
Originally Posted by JayTheCPA
Glad these videos are still helpful, Ron sure made some great videos and he is still missed by many.
Old Dec 16, 2020 | 01:23 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Very much so!
Old Dec 16, 2020 | 09:36 PM
bsiliani's Avatar
bsiliani
His videos are worth watching, even if you are not doing the specific job he is showing. Why, do you ask ?. Because he is a excellent person for the DIY wrencher. He shows alot of tips and tricks along the way in his method and even shows/explains his shortfalls when he is operating. Always explains the tools needed with references on what is needed. Wish he could do more videos. Thanks Ron.
Old Dec 17, 2020 | 05:22 AM
AUM's Avatar
AUM
Reps sent to Rob, he’s been great help down here in SA! RIP
Old Dec 27, 2020 | 10:19 PM
JeepGuy93's Avatar
JeepGuy93
Thanks.
I just pulled my transfer case and my plastic bushings came apart just fine by pulling them apart with a pry bar.
Also note that a 13mm swivel socket along with a second swivel came in handy for this job... I got a set of Kobalt 12 point metric swivel sockets a couple years ago and just used it for the first time.
klh
6.4L Power Stroke Diesel
Aug 29, 2018 03:05 PM
preppypyro
1997 - 2003 F150
Jul 28, 2017 12:18 AM
Hawk180
Aug 14, 2011 04:24 PM
Bluegrassboy70
Sep 3, 2009 11:29 PM
