1998 F150 PCM is missing
You give them the VIN number and they will flash one for your truck so everything works. The truck needs a 4.6 NPI engine put back into or you are going to have to change the engine wiring harness as they came with a butterfly valve on the lower intake and the coil packs were different as they were not on top of the plug, but one big box with wires to each plug. 1999 5.4 was the first year of the PI engines and did not have that type of system and had more horsepower. I want to say the 4.6 did not get the PI engine till 2002 but could be wrong. The wiring harness is one of those junkyard deals where you will have to pull one off a truck.
Places like this do what you want to do. I have never used the below so cannot say how good or bad they are. There are a lot of companies that do this and you will just have to see, The going rate for one is around $200.00 plus or minus if you don't have one to repair.
1-866-253-8035 https://www.protechautosystems.com/p...YaAt2hEALw_wcB
ProTech Auto Systems Computer Replacement
ProTech Auto Systems can replace your vehicle’s auto computer for you should yours need to be replaced.We specialize in providing high-quality auto computer replacements. All we need is your part number from your engine control unit, along with your VIN to program or flash it. Most units come “plug and play” once you receive them. However, if additional programming is required, we will be sure to let you know how to get this taken care of.
