Brake issue
Old Dec 8, 2021 | 08:12 PM
Surgemaster1277's Avatar
Surgemaster1277
Originally Posted by jas88
How old are your brake hoses? They will collapse internally and cause brake pressure to hold on the caliper, then slowly release later on.
This is the culprit for sure.......Id also do the other hose on the other side too as its gonna happen to that side aswell.............
Another thing I would say when you do the hoses is pop the caliper pins pull the calipers off then take a wirewheel on a drill and clean out the rust and crud out from the creases out aswell as the faces where they slide together and put some copper based anti-seize or some wheel bearing grease then reinstall ..
Id also take the opportunity to pull the rotors off to clean out the bearings and races to inspect them for excess wear and replace if needed then regrease the wheel bearings and reset preload.
It will all make a pretty big and better world of difference especially if he takes the extra time to regrease the whole frontend too......
Old Dec 9, 2021 | 07:13 AM
Mbizzal's Avatar
Mbizzal
That sounds like a solid plan. I have already purchased both sides for the brake hoses and they should be here this weekend. I also have copper grease and plan to re-grease the calipers. More than likely want have time to check the bearings. But, I will pull the caps and take a look inside.
I have a ford dealership 4 miles down the road and always get my oil changed there. They grease the fittings with the oil change and seem to do a good job. Had my oil changed a few months back.
Thanks to everyone for the help. Looking to do the job over the weekend.
I will post back hopefully if good new.
Old Dec 13, 2021 | 07:37 AM
Mbizzal's Avatar
Mbizzal
Changed the brake hoses and re-greased the calipers. Everything seems to be working fine after all the work.
Mostly an easy job except for the brake hose to hard line connection. The bulkhead made it very hard to reach around and access the hard line.
Thanks to everyone. Have a great Christmas and New Year.
fordman19762003
Jul 11, 2020 08:12 PM
Fusion7.3
Aug 14, 2014 06:58 PM
Fusion7.3
Aug 14, 2014 05:40 PM
Maddogv21
Oct 3, 2008 06:05 AM
jimbo8
1997 - 2003 F150
Oct 19, 2006 09:06 AM
