Sticky brake or something else?
Old Jul 11, 2020 | 07:36 PM
fordman19762003's Avatar
fordman19762003
Been noticing that when driving the truck after it sits all night or day if I back up then drive forward and touch the brakes I hear a single light clunk coming from the left front. It sounds like the sounds something makes when it hangs up then releases.
Do I have a caliper or something sticking? It only does it once then is fine until I let it sit for an extended period of time.
I haven't taken it to the dealer yet because I only they won't catch it and I don't want to drop the truck off then make the hour drive the next morning to be there only to have them tell me it's normal.
ETA. The truck is a 2019 with 12000 miles.
Old Jul 11, 2020 | 08:12 PM
C12H24's Avatar
C12H24
If the brakes seem otherwise okay, I would not pin it to brakes. You can sometimes get this if the pad retainers or caliper pins come loose. That would be pretty rare. If there was a mechanical fault -ad I'm not writing that there is one- I would say wheel bearing or maybe a U-joint.
You're right. Dealer won't do anything with it unless they can duplicate a complaint and it's very obvious. I would ignore it until it presents itself as a constant problem
QwkTrip
2009 - 2014 F150
Jul 23, 2015 08:31 PM
gmcretz
Mar 22, 2015 03:45 PM
Pit Crew
Mar 19, 2015 07:48 AM
Fusion7.3
Aug 14, 2014 05:40 PM
FarmingFord
Mar 31, 2009 11:50 AM
