Sponsored by: Real Truck
Dana 80 axle assembly
Old Dec 12, 2020 | 08:51 AM
Trinbagosfinest's Avatar
Trinbagosfinest
New to diesel and also the forum.
1999 F450 7.3 2WD DANA 80 with 4:88 10 bolt with 19.5 tires 201k.
Leaking axle seal
Everything else looked fine from what I could see.
Howling in the drive train only when accelerating. Over 15mph if I'm on the accelerator I hear the noise.
Popped open the differential cover and see chipped teeth on the ring gear (possibly failed bearing).
The question is "should I rebuild or replace the entire axle assembly? "
I was told by Ford that the carrier housing could also be damaged and i also have to replace axle seals and bearings.
Old Dec 12, 2020 | 11:42 AM
Just Strokin's Avatar
Just Strokin
I would replace it. The cost would probably be similar either way. You can possibly find a later model setup that will bolt in with no issues.
BlueWhiteFord
Apr 28, 2020 09:01 AM
Mason R
Jun 9, 2017 07:38 AM
1964FORDTUF
Ford Truck Parts for Sale
Oct 16, 2016 05:46 AM
quadzjr
Offroad & 4x4
20
Mar 20, 2008 03:50 PM
Slow
Aug 21, 2007 03:20 PM
