Fox 2.0 Performance Series Availability
Old Dec 12, 2020 | 08:35 AM
super_duty_532's Avatar
super_duty_532
I just ordered the readylift 2.5 leveling kit for my 2018 CCLB and wanted to also upgrade the shocks to Fox 2.0s. But it seems I can’t find them anywhere in stock, especially the front ones. I believe the Fox part number is 985-24-155 for the 2-3.5 lift version. Any suggestions? I want to get this done soon and am thinking might just get some Bilstein 5100s instead. Truck is mostly on road unloaded and only see offroad or heavy loads occasionally. Would Bilsteins be a downgrade from the Fox’s from on road ride quality perspective?
Old Dec 12, 2020 | 09:35 AM
ford390gashog's Avatar
ford390gashog
The shocks are available, they are low stock but I ordered my set just fine and they arrived. I did these on my work truck and I used the Elka shocks on the wife's truck. I do prefer the ride of the Elka but the Fox shocks are a value compromise.
https://www.shocksurplus.com/product...32323195109425
Old Dec 12, 2020 | 09:50 AM
super_duty_532
Thanks. The link seems for the reservoir version. Also the 2-3.5 lift model is unavailable. I was actually thinking about the IFP version. These reservoir ones almost doubled the price. Would you think they are a big improvement over the single tube ones?
Old Dec 12, 2020 | 10:15 AM
JD'sBigredv10's Avatar
JD'sBigredv10
I ordered a 2 1/2" leveling kit with the Fox 2.0 upgrade and an adjustable track bar from PMF Suspension on 11/30. All the parts arrived two days ago.
Old Dec 12, 2020 | 11:11 AM
speakerfritz's Avatar
speakerfritz
the reservoir ones are a big improvement on rough off road.
the oil in the shock s get hot as they operate and as they get hot...they tin out vescosity........reservoir shocks have more oil and they take longer to heat up.
not needed for on road use..
Old Dec 12, 2020 | 11:30 AM
4wd6.7L's Avatar
4wd6.7L
Maybe... https://www.ajusa.com/985-24-155.html
Old Dec 12, 2020 | 12:10 PM
AMXDREAMER's Avatar
AMXDREAMER
I have a car buddy that was an engineer with a major shock company (retired now). I asked him his opinion between the Fox 2.0 and the Billstein and he said the Billsteins are a better shock and that the Fox 2.0 are over rated.
Old Dec 12, 2020 | 12:36 PM
ford390gashog
if you are not going reservoir go with Bilstein. To see a dramatic difference you would have to go reservoir due to the valving difference and the damping action.
17PlatinumSFL
Jul 18, 2020 06:02 PM
Leovardo
Feb 11, 2020 06:22 PM
gtnwood
Jan 14, 2011 11:00 AM
donbeeler49
2004 - 2008 F150
May 4, 2009 04:20 PM
sdmotor
Jul 9, 2002 09:34 PM
