Inline 6 to 351w
Would it be a T-18?
Thanks
Is first gear really low, as in a crawler gear? If so, it will hold.
OR
Is it geared like a 3 speed, with 4th gear being overdrive? If so, drive it easy.
T 18 pictured here:
https://www.novak-adapt.com/knowledg...anual/t18-t19/
Overdrive:
https://www.ford-trucks.com/forums/a...2&d=1295571478
or
https://www.jalopyjournal.com/forum/...drive.1053885/
or
https://www.advanceadapters.com/tech...-transmission/
OR
T 18 pictured here:
Overdrive:
or
or
If you can look at the transmission, the most obvious difference is the top cover. The T18 is cast iron like the case, and the NP 435 has an aluminum cover.
