Sponsored by: Real Truck
5R110W
Old Dec 11, 2020 | 01:35 PM
cholt123's Avatar
cholt123
5R110W
New member, appreciate any help in advance. I have a 2010 f250 with a 5R110W that started to have shifting issues. Took the truck to 2 different transmission shops and was told i needed the trans rebuilt. So I had the transmission rebuilt and it lasted 2 weeks, then pulled a D solenoid code and lost communication to TCM. Took the truck back and was told it was fixed for the second time. Lasted 10 miles this time and is pulling P1000, P0766, P1635, P2703. (no lost communication this time) The truck will only shift to 4th gear @ 2000RPM's at 55mph. It also shudders when going into reverse. The truck will shift into 5th gear, when cold, after the codes are cleared for about a mile and then reverts back to only making it to 4th gear and high RPM's. The truck had a SCT GTX tuner with custom tune when purchased. Fluid is a little darker than normal. Transmission shop told me that they replaced all electronic solenoids and valve in the transmission. TCM was not changed. Any ideas? Thank you
Danny Parker
New Member Introductions
Nov 12, 2017 08:44 AM
MaxxSpazz2!
Aug 21, 2017 03:05 PM
