Running 40 psi sounds like that's where I need to be. But the chalk test sound like that would be a true test how much rubber is on the road. Thanks everyone
From what I can see on those posted door stickers, the different tire pressures listed are in direct relationship to the also posted weight/payload capacities so simply asking "what pressure is best" is not the question to ask. It is is, as we should all know, specific to each situation
On trucks that have tire pressure monitor in dash dispay to call up; it's an education on how each tire moves in pressure from cold to hot and under driving conditions and large temperature changes.
Tire pressure almost becomes relitive after a cold start.
After awhile you could begin to detect a tire that heats up at a different rate and even a monitor that is 'off' from the other three if you set all four with a good digital gauge and watch the trend long enough over many drive cycles.
A lot goes on with the tires we never suspected in the past without this ability to see it..
I have the same issue with 'mom' objecting to hard hits so lowered the tire pressure for accomidation.
What we need to understand is the trucks are shocked a bit stiff OEM.
Otherwise I get 21 mpg on a 2018 5L on lowered cold tire presuure that only rises back to 35 +/- during driving. Handling is not 'substancially' different.
