9000 mile OCI?
Some folks wrap the media with paper towels to wick excess oil out of the media to make it easier to see larger debris, others cut & fold the media into a block, held between two pieces of scrap wood, place that assembly in a vice & Squeeze the excess oil out that way but I wonder how much media contained Depth debris is dislodged, to weep out with the oil, so we might think the media is cleaner than it really is??? But if your not interested in what its caught, just if its torn, or how many square inches of media the filter has, its faster to squeeze it dry for inspection.
1999 F250 5.4_ 250k miles, Motorcraft 5w20 synthetic blend & Motorcraft filter. 5,000 mile oil changes.
2008 F350 V10_ 200k+ miles, Motorcraft 5w20 synthetic blend & Motorcraft filter. 5,000 mile oil changes.
2012 F250 6.2_ 213,800 miles, Motorcraft 5w20 synthetic blend & Motorcraft filter. 7,000 mile oil changes.
The new 2021 7.3_ 52,000+ so far, Motorcraft 5w30 synthetic blend & Motorcraft filter. 7-10,000 mile oil changes.
88 F250 I6 engine, used whatever dino oil, over 250k miles. 3-5k mile intervals.
95 F350 351 engine, used whatever dino oil, over 250k miles. 3-5k mile intervals.
My personal motorcycle, car, and truck log very few miles. My work truck gets up to 300 miles daily. But that doesn't mean I drive that much every day. On some days, it's a little less. The first week of every month, it gets an oil change. It gets the fleet service oil change of generic oil and filter. All fluids are serviced as needed. All wear items are replaced as needed. Even with the cheapest oil and filter, I have yet to see one of these trucks fail with a seized engine. But then again, businesses tend to replace trucks every 3 - 5 years or 250,000 miles. Maybe the engines seize on the next guy, at 300,000 miles. Then his mechanic will tell him that the engine was dirty from hundreds of thousands of miles, using cheap oil and filters.
Finally found a way to remove the filter element completely intact--simply used tin snips to cut the can away. There's little to no chance of any cutting debris from grinding, drilling etc falling inside. Also found Blackstone has a service they'll inspect the media and report their findings, much like their oil analysis.
Bad news is that's upwards of $125 per test, I was a bit sticker shocked (
) but may still go forward for my own piece of mind. I also have the previous oil filter that had over 6K miles on it in use, may go the DIY inspection route to simply see what I can or might find inside it.
