low speed detonation
Old Oct 27, 2003 | 07:40 PM
wolfen's Avatar
wolfen
Hey Ranger95,
You've got to fill us in as to where you heard about this Sea Foam idea+why it works! I have an open mind and I'm always willing to learn+ try new things!
__________________________________________________ __
Hi saskatchewan ,
Are these plugs hotter than the ones you had in there before that you may know of?
Ranger95's decarbonizer sounds right! (Carbon build up creates HOT-SPOTS, hence your low speed detonation problem!)
Maybe check w/ the place you purchased them from.
I'll check to see if there are any threads pertaining to this same question and I suggest that you do the same.
You also mentioned Canada! How come you don't say "Ae" in every sentence, Ae?
‘90 Ranger XLT: 2.3L, EEC-IV, EFI, DIS, 2wd, Mazda 5sp 127K/mi
Old Oct 27, 2003 | 07:45 PM
Ranger95's Avatar
Ranger95
Ok. I read it somewhere, can't remember were, this is a Multipurpose engine cleaner, oddly called Sea Foam, what you do is you pour about 1/3 of a pint into a vaccum hose (I used the Brake Booster Hose) and it will lead into the pistons creating a huge smoke cloud, more like burning oil, but what's really happening is that you're burning the carbon deposits. you can read more on their web site, http://www.seafoamsales.com
Old Oct 27, 2003 | 07:52 PM
wolfen's Avatar
wolfen
Hi Ranger95,
Got to check this site out! Beats the Jiffy-Lube Decarb price wise!
saskatchewan's Avatar
saskatchewan
Hi again
I checked out that Sea Foam stuff on its web site. It looks pretty crazy. I will have to see if I can find it. How did you put it in the Manifold?
Did you just pour it in the throttle body?
As for the plugs, I used the ones recommended by NGK however, I set the gap a bit more narrow. I many just put in a set of Ford plugs and see if there is an improvement.
As for "Eh". I come from western Canada so, I talk more like someone from Montana. When I was in Italy last year and periodically attempting to commit Italian, people kept asking me if I was from Mexico!?!?
Still have not figured that one out.
Any more automotive suggestions (on things other than the way I talk)?
Old Oct 27, 2003 | 07:57 PM
Ranger95's Avatar
Ranger95
What I did:
I poured about 1/3 of the can into a container, then I disconnected the Brake Booster Hose at the booster.
With the engine running I put the hose in the container with the liquid, making sure not to cause a hydrolock.
Turn the ignition off after the whole liquid is absorbed by the vaccum
Waited about 5 min and cranked it again (at this time the hose is back in place)
Big smoke cloud for about 30 min (is normal) and reving it once or twice to make sure is burning all the deposits.
Old Oct 27, 2003 | 08:09 PM
wolfen's Avatar
wolfen
Hi saskatchewan,
Just mess'in around with ya', nothing personal...1 big happy family we have here @ FTE!
So...
What are gapping you plugs with+what you setting them at? Under you hood, on the radiator shroud/cover, there is a "VECI label that will tell were they should be set at.
Old Oct 27, 2003 | 08:20 PM
saskatchewan
Hi
I seem to recall that I gapped them at 44 thousandths but, I will have to check my service book to make sure.
I looked it up in the Haynes guide and I thought that it said 42 to 46 thousandths.
Old Oct 28, 2003 | 09:58 AM
saskatchewan
Has anyone tried Clean Flow system for removing carbon deposits?
