EcoBoost (all engine sizes) 3.5L Twin Turbo EcoBoost V6, 2.7 Twin Turbo EcoBoost V6, 2.3l/2.0L I4 EcoBoost Engines
F150 Overheating
Old Dec 10, 2020 | 11:27 AM
czufelt's Avatar
czufelt
F150 Overheating
My 2018 3.5 ecoboost engine and transmission overheats when pulling a grade with a trailer for much distance at low speed (rough mountain roads under 20 mph). The first time this happened the engine actually went into shut-down mode and tranny was at 244 degrees. Since then I've found I can avoid this by shifting into 4 X 4 Low but that seems like less than a great idea. The local ford dealer tells me Ford is aware of the problem but has issued no fix. Any suggestions?
Old Dec 10, 2020 | 12:08 PM
ford390gashog's Avatar
ford390gashog
Not a common issue, are the fans not coming on? There was early build gen two 3.5 built from 2017-2018 that had weak thermostats and should be replaced.
JRTJH
2009 - 2014 F150
Jun 30, 2011 12:11 AM
acooya
2004 - 2008 F150
Jun 8, 2005 01:03 AM
LA_BigRed
28
Feb 28, 2005 07:41 PM
sink
Feb 18, 2004 04:57 PM
89fordf150
Jun 11, 2002 11:53 AM
