Engine RPM while idle issue!
Old Dec 9, 2020 | 05:12 PM
Eng.baomar's Avatar
Eng.baomar
Exclamation Engine RPM while idle issue!
Hi all,
I have started noticing that whenever I stopped the vehicle & especially when open the door, the engine RPM goes up and reaches around 1200 RPM.
Also sometimes while the vehicle is idle.
The last few things done before starting to notice the issue was when I did some FORScan coding as follows:
1- adjusting the speedometer reading with GPS.
2- Enabling Secure Idle
3- Enabling Auto re-lock
4- TPMS Placard Tire Pressure Display
Wondering if any one has faced the same!
link to the video in below link:
https://1drv.ms/u/s!Avf160diPUZmk3ns...kApUu?e=WxJSnn
Cheers
Old Dec 9, 2020 | 05:24 PM
GABAR's Avatar
GABAR
Originally Posted by Eng.baomar
Hi all,
2- Enabling Scure Idle
Cheers
Put it back to stock.
If the problem goes away then you’ve 100% narrowed down the problem and what’s causing it.
FORScan can show one how to change things but they can’t tell you how to fix any problems that might show up afterwards.
Old Dec 9, 2020 | 05:59 PM
Eng.baomar's Avatar
Eng.baomar
Hi mate;
matter of fact I'm considering of undoing the above and have a lock again, and at the same time wondering if the cause might be something else though !
Old Dec 9, 2020 | 06:12 PM
GABAR's Avatar
GABAR
Hi mate;
If you do put it back to stock and the problem still exists, you might want to run a scan on your vehicle to see if there are any codes.
Something like this can be very annoying to track down.
You might need a tune up / new spark plugs, maybe better gas, could be a dirty throttle body, etc, etc.
Old Dec 10, 2020 | 05:21 AM
Eng.baomar's Avatar
Eng.baomar
the spark lugs were replaced just couple a week ago. I will undo the above mentioned mods and check back again. hopefully will be able to pin down the issue.
Old Dec 18, 2020 | 08:20 AM
Eng.baomar's Avatar
Eng.baomar
Hi all,
just a follow up, I’ve solved the issue be un doing Secure Idle code by FORScan.
Old Dec 19, 2020 | 05:18 AM
GABAR's Avatar
GABAR
Lol......Damn FORScan mods.
Old Dec 21, 2020 | 09:43 PM
Eng.baomar's Avatar
Eng.baomar
It is fun though
Old Dec 21, 2020 | 09:46 PM
ford390gashog's Avatar
ford390gashog
Thats a standard feature on SSV F150 trucks, they will idle up to 1200rpm. It seems you found the magic combo.
Old Dec 22, 2020 | 08:27 AM
scott91370's Avatar
scott91370
Now make the same changes one at a time and see which one caused it.
Btsiera
Jan 26, 2020 07:25 PM
raven3
5.0L Coyote
Feb 10, 2015 05:35 PM
CA-F250
6.7L Power Stroke Diesel
Nov 18, 2012 07:22 PM
spd800
Modular V10 (6.8l)
Aug 21, 2007 09:51 PM
Larri
Nov 6, 2003 01:01 PM
