idle problem
Old Nov 5, 2003 | 06:18 PM
Larri's Avatar
Larri
Unhappy idle problem
hi, What i should do or check? before my truck's idle is above 500 rpm suddenly, a day i start the truck the idle goes down to 500 rpm sometimes it shut off... it is safe that I will used a air intake cleaner? or Ill just adjust the idle higher? Thank you... Ill be waiting... name is Bench...
Old Nov 5, 2003 | 06:22 PM
Larri's Avatar
Larri
Old Nov 6, 2003 | 01:01 PM
Dialtone's Avatar
Dialtone
Read the Sticky Link at top of first page entitled "IAC Repair Help".
Should answer most of your questions.
Dialtone
