Superduty Complaints Lets hear them
I love my new truck, it's powerful, capable, quiet, drives great, handles the trailer well and is just nice in general.
There are a few things that I think Ford royally screwed up though, a few things that I cannot stand and that I can't believe they ever made it through the testing stages. The first of which and the one I hate the most is the stupid electronic turn signal, high beam stalk. Next level impossible to make quick lane changes when driving around in the busy parts of town, you constantly have to look down and see whether you managed to switch the indicator from one side or the other or turned it off. The high beams is just annoying because to check if your high beams are on you either need to pull the lever in turn flashing the oncoming traffic or continuously look down to make sure the little blue light is off rather than just checking with your finger whether it is in the forward or backward position.
The next is the seats, I have never owned a vehicle with such uncomfortable seats, it feels like there is some sort of hump mid back level, changing the lumbar support makes no difference since it is lower down, on the topic of the seats the seatbelts run right over the seat back adjustment and make it difficult to pull and then go and get caught underneath it after you let go.
What the heck, is it just me or is anybody else noticing these things? If anybody has a fix for any of them too, especially the indicator stalk let me know.
Let's hear what everybody hates about their Superduties.
I am a little shocked that nobody seems to have an issue with this setup. I figured it had to be a common complaint since Ford went back to a real indicator stalk on the newer ones.
To whoever the wise guy was that said I should just buy a different brand of truck. What?! I thought that these forums were all about community and modifying and fixing vehicles to be the way that we like. Nobody makes a perfect truck and things can always be improved. I was just looking for like minded individuals that maybe had ideas to modify or replace with older/newer models to eradicate the issue.
The wife's first complaint was "I hate the blinkers work in your truck"
I'll list some complaints.
-Expensive cam phaser issues
-Spark plugs break
-An XL doesn't need TPMS
-The TPMS light is annoying AF
Seriously, why does any truck need a TPMS system? I know when I have a flat. It's not hard to notice with 31" tires.
The only complaints I really have are over the HVAC. If you don't know what blend door actuators or the evap temp sensor does and what happens when they stop functioning correctly, I suggest researching them and what needs to be done to repair them.
-Spark plugs break
If anybody knows how to get rid of the 911 assist garbage too let me know. Mine tells me it isn't operational and that I should go to the dealership every morning.
