The 5,409 cc (5.4 L; 330.1 cu in)[4] V8 is a member of the Modular engine family first introduced in the 1997 F-series pick-ups, in place of the 5.8L 351W. Bore diameter is 3.552 in (90.2 mm) and stroke is 4.165 in (105.8 mm), the increased stroke necessitated a taller 10.079 in (256.0 mm) engine block deck height. A 6.658 in (169.1 mm) connecting rod length is used to achieve a 1.60:1 rod to stroke ratio. The 5.4 L 2V was built at the Windsor Engine Plant, while the 5.4 L 3V moved production to the Essex Engine Plant beginning in 2003, then back to Windsor Engine Plant in 2009.[48] The SVT 5.4 L 4-valve engines are built at Romeo Engine Plant, hand assembled on the niche line.[49]
