Power Lock and Window...
Old Dec 8, 2020 | 01:21 PM
F TOO FITTY's Avatar
F TOO FITTY
So the rear passenger lock on my 2009 quit working. I put it on the list of things to address at some point, but have just been leaving it locked. If I need in there, I can reach back and manually unlock/lock it. But now I noticed that the rear passenger power window doesn't work either. So I was thinking a wiring harness to that door was messed up...
...but the window still works when controlled by the driver's control. Any ideas or suggestions on a troubleshooting path? I obviously don't want to buy parts that aren't needed to fix this.
Thanks in advance...
Old Dec 8, 2020 | 03:04 PM
rbentnail's Avatar
rbentnail
Child safety feature?
Old Dec 8, 2020 | 05:10 PM
F TOO FITTY
i just double checked that, since it would make sense that the driver could still operate it. But the driver control won't lock/unlock either; it only makes the window go up and down
Old Dec 8, 2020 | 10:34 PM
gDMJoe's Avatar
gDMJoe
Lightbulb
Chafed, broken wiring in/between the door and pillar.
Old Dec 10, 2020 | 02:13 PM
F TOO FITTY
you nailed it. after reading your reply I did some quick searching and found that this is very common on these trucks.
Then I looked at mine and sure enough - 2 wires broken and 3 others chafed. I held them together to test, and both the lock and window worked
now I need to set aside some time to fix this permanently. Kind of close quarters, but I'll figure it out. Thanks a bunch!
Old Dec 10, 2020 | 11:26 PM
Lime1GT's Avatar
Lime1GT
I changed the door harness in my brothers 2011. It took less time to install than to repair the multiple wires cracked and broken.
Old Dec 15, 2020 | 01:12 PM
F TOO FITTY
ya I was looking at a new harness (or 2, since the other side will most likely have this problem eventually). Is the new harness redesigned at all? Or is it just going to do the same thing in 4 or 5 years? Maybe I could reinforce it a bit...
Thanks!
Old Dec 15, 2020 | 07:13 PM
Lime1GT's Avatar
Lime1GT
It didn't look any different to me. Ford should have offset the door to cab holes more. That would have allowed the harness to twist as well as bend instead of just bending in one spot.
Old Dec 15, 2020 | 09:04 PM
90Ford73's Avatar
90Ford73
My 09 does this every couple years, and the wires broke again last month. I just leave the door locked, its a pia but I can work around it till I get the time to fix it. I've been meaning to price out a harness from the dealer, I'm running out of material to splice too lol. Maybe a guy could buy a new harness, and then solder in an extra inch of wire?
tjc transport
Feb 4, 2020 05:56 AM
shrtmem
Dec 30, 2019 09:43 PM
seamus6868
1978 - 1996 Big Bronco
Jun 27, 2008 09:14 AM
shift1313
Jul 9, 2005 10:53 PM
