View Poll Results: How do you want the hobby to progress
Highly traditional
0%
Light aftermarket improvements
71.43%
Strong aftermarket improvements
14.29%
Restomod all the way
14.29%
Voters: 7. You may not vote on this poll
Bedliner on cabfloor
Old Dec 15, 2020 | 10:00 AM
FuzzFace2's Avatar
FuzzFace2
On my 81 F100 I built as a driver, cab off frame rebuild, I did 2 coats of roll on bed liner top & bottom of the floor before putting cab back on frame.
I used the truck for a bit just that way and can tell you it did nothing for noise. little rocks hitting the floor bottom sounded like gun shots!
I think it has stood up pretty good so far. I left it black as that was what the rubber floor mat was.
A few month back when I installed the over drive unit I installed a used carpet someone gave me and that made it real quite.
The floor is shinny because it is still wet, it got a little less when dry.
The custom metal ribbed floor I made to replace the wood floor, flare side, had lineX on it from the parts truck I just did 1 roll on coat to make it look good again.
Because I use the truck, not heavily yet, I don't worry about hurting the floor.
Floor marked with white paint when building it
Dave ----
Old Dec 15, 2020 | 10:43 AM
Fomoko1's Avatar
Fomoko1
The steel floor looks good Dave. I was thinking of doing the same with my 53 but in the end I decided to go with wood.
Old Dec 15, 2020 | 11:06 AM
FuzzFace2's Avatar
FuzzFace2
Thanks
Don't get me wrong I love the look of wood beds but for the cross members and F&R sills was $1000.
Then add the wood, metal strips and the hardware it was just not in the bank to do.
Heck the truck was $800 to take the trash to the dump weekly. I needed to do a few things to make it safe and it got vary out of hand LOL
Cab off frame rebuild, floors, rockers, cab corners, rear door posts, lower inner & outer left door.
The bed floor came from a $400 parts truck that rolled, so the sides were trashed but the floor was good.
What is nice with the ribbed floor is the water & dirt drain out the front and not sit in the bed to rust it or rot wood.
I took the parts truck AC firewall and grafted it on my truck so I have factory AC.
Also took the factory dual tank setup and added it to my flare side to look factory, it was never an option for a flare side.
I even customized the bumpers, no bolts, and added driving / fog lights to the front bumper.
Only took me 4 years almost to the day and I did all the work myself.
Dave ----
Old Dec 15, 2020 | 11:34 AM
Fomoko1's Avatar
Fomoko1
Wood bed kits are way too expensive so we cut pine plywood into strips, stained and varnished it. Not sure how it will stand up but mine isn`t a work truck so hopefully I get more than a few yrs out of the bed.
Old Dec 16, 2020 | 07:59 AM
sifton's Avatar
sifton
I used a good quality bed liner on my cab floor and underside of the cab. The box floor got it also, then I covered it with aluminum checker plate.
Old Dec 16, 2020 | 03:16 PM
Fomoko1's Avatar
Fomoko1
Sounds like you have it all covered Dave.
Old Dec 16, 2020 | 05:02 PM
FuzzFace2's Avatar
FuzzFace2
What is nice of this site is you get to see what others have done or doing to their projects and pick what you think would work best for your project.
I don't only check out my 80 - 86 truck area but all of them and why I am here.
Dave ----
Old Dec 16, 2020 | 06:36 PM
Fomoko1's Avatar
Fomoko1
I come here cause I`m a mod but I also like fridges a lot. As well some of the mechanical components are same or very similar to 53-56 trucks.
Old Dec 17, 2020 | 05:02 PM
spurredon's Avatar
spurredon
Plus we use to be in the same group awhile back.
Old Dec 17, 2020 | 11:24 PM
Fomoko1's Avatar
Fomoko1
I wish it still was the same group but in some ways I guess it is better.
Old Dec 18, 2020 | 07:52 PM
spurredon's Avatar
spurredon
Plus there use to be Julie! lol
Old Dec 18, 2020 | 11:07 PM
Fomoko1's Avatar
Fomoko1
Can`t forget ''it'' tho I`d like to.
Old Dec 19, 2020 | 05:31 PM
  #28
spurredon's Avatar
spurredon
"It" was entertaining at times!
Old Dec 19, 2020 | 06:20 PM
  #29
Fomoko1's Avatar
Fomoko1
Not the kind we like to see but it was ''an entertainment'' of sorts.
Old Dec 19, 2020 | 06:53 PM
  #30
Red60's Avatar
Red60
