Releasing hose clip
Old Dec 6, 2020 | 04:34 PM
Dodgeyaussie's Avatar
Dodgeyaussie
Releasing hose clip
Pulling the intake off a 2005 Ranger 2.3 and can't figure out how to release the clips that hold this hose on. I poked around a bit and didn't want to risk damaging anything...
Old Dec 19, 2020 | 08:44 PM
ranger pat's Avatar
ranger pat
Veteran: Navy
Don't know for sure, but it looks like if you gently pry upward on the white tab with a small screw driver, it will raise fingers that lock the hose to it's connection.
Old Dec 20, 2020 | 09:32 AM
Tomget's Avatar
Tomget
Yes..I agree with Ranger Pat...I've got a 92 2.3L and I haven't had to do this recently..but as best I recall the little white plastic device
is the "locking tab" so to speak..pull it up and it unlocks the connection
Old Dec 24, 2020 | 11:57 PM
78Broncoinpieces's Avatar
78Broncoinpieces
push the white part down about 1/16" then pull the connector off. (unless the connector is oriented up-side down, then reach underneath and push up)
the white piece has an oval shaped hole going around the nipple, pushing it down causes a lip to clear the raised ring on the nipple.
the white piece has 2 small tangs on the bottom that push it upwards to the locking position.
to reinstall just push the connector on, the white piece simply snaps over the ring on the nipple and locks the connector on.
the white piece stays inside the connector.
williamlreidlll
Dec 6, 2020 05:58 PM
ztodd377
May 6, 2020 11:44 PM
truckguy92
1997 - 2003 F150
Jan 10, 2020 09:29 PM
vjsimone
All Other Items for Sale
Dec 17, 2017 10:29 PM
Javi1
6.7L Power Stroke Diesel
22
Mar 21, 2015 09:44 AM
