Sponsored by: Real Truck
Best pre-Godzilla gas engine
Old Dec 6, 2020 | 03:26 PM
2002Limited's Avatar
2002Limited
All other things being equal, which would tow a 13K fifth wheel the best? 3-valve 6.8 with the 5 speed transmission, or the early 6.2 with the 6 speed? Basically, 2010 vs. 2011?
Old Dec 6, 2020 | 03:57 PM
Just Strokin's Avatar
Just Strokin
Well, I would go with the 2011 and newer. The 6.8 is only used in heavy duty chassis or trucks now. The 6.2 seems to hold up well.
Old Dec 6, 2020 | 04:43 PM
AK4x4's Avatar
AK4x4
For gas engines of that vintage the 6.8 V10 is best, more torque due to more displacement and more horsepower. The 6.2 is also a fine engine, just not as strong as the 6.8. Make sure the truck has low (numerically high) rear axle gearing for pulling that much weight. Good Luck, Russ
Old Dec 6, 2020 | 05:02 PM
ford390gashog's Avatar
ford390gashog
I prefer the 6.8 to the 6.2. I had a 2010 F350 4.30 gears and the v10 and it pulled much better than the 2011 6.2 that replaced it.
Old Dec 6, 2020 | 06:24 PM
Bugzilla46310's Avatar
Bugzilla46310
If the 6.8 was offered in 2016 on the F350, I would have it in my 2016. I liked the way the V10 pulled in my 2000 with the manual transmission. I feel it pulled as well, maybe better, than my 2016 with the 4.3. My 2000 had 3.73 rear end.
Old Dec 6, 2020 | 07:15 PM
2002Limited
I really like the 2005-2007 vintage. Currently, I have an Excursion, with the 2 valve 6.8 and 4r100 and 3.73 gears. It pulls our 10K TT well, albeit in 3rd gear pretty exclusively. Since we are going fifth wheel in the next few years, I'm looking for something close to what I am comfortable working on. It seems like the 5 speed auto essentially splits two gears around the old 4r100's first, with the top three ratios being the same. I've never felt the old v-10 lacked for power, and feel that a 3-valve with 4.30 gears and the 5 speed automatic should pull really well. Also don't want to spend over 20K for a truck because I'm cheap.
TheMcNabs
Escape & Escape Hybrid
Aug 15, 2020 08:38 PM
TPScoversheets
All Things Towing
19
Aug 1, 2020 02:19 AM
TheLex
Oct 16, 2017 12:12 AM
maxu13
1978 - 1996 Big Bronco
23
Aug 2, 2006 07:50 PM
hookspacken
Jul 22, 2003 05:11 PM
