Dana 60 Drum lock nuts torque
Old Dec 6, 2020 | 11:03 AM
Old Guy F-250's Avatar
Old Guy F-250
Guys,
Quick question,
What is the PROPER torque for the brake drum nuts on 79 250 Dana 60?
Thank you, Alex
Old Dec 6, 2020 | 02:38 PM
1TonBasecamp's Avatar
1TonBasecamp
Hey Alex. You're talking about the big hex nuts for adjusting the wheel bearings? Or something else like the backing plate bolts?
Paul
Old Dec 6, 2020 | 02:48 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
https://www.ford-trucks.com/forums/1...l#post16908327
"Dana 60 full floater - Rear wheel bearing adjusting nut - 50 -80 ft lbs, back off 1/4 - 3/8 turn. (Check for play). Lock washer - bend a tab or two over the adjusting nut, or use the same bent ones in the same place.
Wheel bearing locknut - 90 - 110 ft lbs.
Axle shaft retaining bolts - 40 - 50 ft lbs.
Between 65 and 75 ft lbs.. spin... tighten.. repeat.. repeat... repeat... until torqued,, then back off 1/4 turn... put on lock washer.. put on second nut.. torque to spec.. then bend tabs over both nuts.. in either direction.. in at least two places on each nut
2 9/16 thinwall axle nut socket...1/2 inch drive, I bought mine at O'Reilly's out of their catalog.
This one is for those of us with Dana 60/70's. The usual spindle nut set of 3 pieces (a nut, washer with tabs to fold over, and another nut) usually work alright, but there is an easier way to go.
Ford part # E8TZ-1A124-A is all three of those in one. It is a one piece ratcheting style locknut that all you have to do is torque down and go. It takes a 4 prong style spindle nut socket. I have them on my front 60 and rear 70 and they work great. They cost about $45 apiece from my local Ford dealership."
https://www.pavementsucks.com/thread...dana-60.59774/
https://torqueking.com/category/1977...-60-rear-axle/
https://www.pirate4x4.com/threads/da...e-spec.215294/
https://www.pirate4x4.com/d1/tech/bi...DFs/index.html
Old Dec 6, 2020 | 02:52 PM
1TonBasecamp
Thanks Rich! Never thought of converting to the new style, so didn't even check to see if they were the same size and all that. Good to know.
While I don't mind the adjusting procedure, I would love to just tighten and go! Means I'll have to buy another tool, but hey, you can't leave too many tools when you die.
Paul
Old Dec 6, 2020 | 02:54 PM
77&79F250's Avatar
77&79F250
That tool (4 prong ratchet socket?) might be able to be rented from most parts houses that offer a tool rental program. Why buy a tool you are going to use once in a while...rear brake shoe replacement/bearing repack time.
Old Dec 6, 2020 | 06:37 PM
Old Guy F-250
WOW,,
Thank you guys for all the trusted information.
When I see things on u tube and web sites, I just don't tend to believe all that stuff.
You guys are great.
I really do appreciate your time and sharing your knowledge with us...
Alex
jwmisenheimer
Jan 27, 2019 08:23 PM
30over
Oct 5, 2013 11:40 AM
genscripter
Nov 16, 2012 07:56 PM
wfodickinson
Aug 24, 2006 05:45 PM
