Spindle Stops
Old Dec 5, 2020 | 04:00 PM
blake in spokane's Avatar
blake in spokane
Spindle Stops
Is there any spindle stops on a CPP Mustang ifs? Or do you crank the power rack till something rubs, stops or brakes.
Old Dec 5, 2020 | 05:16 PM
Last chance 53's Avatar
Last chance 53
The rack has nylon stops that fit between the rack housing and tie rod inner end. They make kits to add stops if needed. What is your problem?
Old Dec 5, 2020 | 06:00 PM
blake in spokane
I was mocking up the front end getting ready to install the coils & didn't see any type of stop bolt. Who makes that kit in case I need one? What about brake hose location thru the frame where the coils are now?
Old Dec 5, 2020 | 06:32 PM
Last chance 53
Most fox body mustang parts suppliers have them, I know LMR mustang sells them. The best way to locate the brake hoses is to put caliper on and attach hose to it and hold other end at frame and turn wheels back and forth and make sure it will clear everything. My hoses are mounted on top the frame just in front of the upper control arm.
geetoe
20
Aug 29, 2019 10:11 PM
tseekins
General Automotive Discussion
Aug 28, 2019 10:02 AM
BarryMc
Feb 3, 2008 03:44 PM
Baer
Aug 1, 2007 06:51 AM
elemint
13
Oct 13, 2004 05:30 PM
