4.10 swap
Old Oct 23, 2003 | 11:54 PM
1 bad 300's Avatar
1 bad 300
4.10 swap
I have a 1993 F-150 with a 300, 5 speed manual, 3.05 gears, and my tire size is 235/75/15. I was thinking about swapping my 3.05 ring and pinion for a 4.10. Right now when I'm doing 75 i pull about 2000 rpms. How big of a change will there be?
P.S. I'm not realy woried about the gas milage.
Old Oct 24, 2003 | 12:38 AM
yellowjeep76's Avatar
yellowjeep76
you'll probably be pulling close to 3000 with that arrangement. just remember that the faster you spin the engine the more wear you cause. you may want to consider a less drastic change. what do you need the lower gers for?
Old Oct 24, 2003 | 12:42 AM
1 bad 300's Avatar
1 bad 300
Well my truck already has 180000 miles on it and it is running strong. The way i drive it it will be notime before I'm rebuilding the motor anyway. The reason i want it is for racing.Do you think that 3.83s will be better?
Old Oct 24, 2003 | 12:49 AM
yellowjeep76
the 4.11 will give great takeoff but i don't think you'll have much top end.... you'll run out too quick. personally i think something like 3.73 or 3.83 would be better. i'm sure someone else here has had experience with these ratios and can comment more. I have 3.55 with my 5.0 running 255/55/18 and 3.00 with my 6cyl running 31" 10.50. At 75 in overdrive with my AOD tranny and 5.0 i'm turning about 2500 rpm
Old Oct 24, 2003 | 12:52 AM
1 bad 300's Avatar
1 bad 300
OK Thanks for the advise. I thought about going with the 3.83 so that might be what im going with. Thanks
Old Oct 24, 2003 | 02:05 AM
william_ace's Avatar
william_ace
i have 33's and am thinkin about gettin 35s would these gears be good for that, im sure they were, and if i were to stick with the 33s what would be the best ratio. thanks
Old Oct 24, 2003 | 11:04 PM
92 f150300six's Avatar
92 f150300six
if the truck is being used for racing i would go with 4.10s im going to run 4.56 with 38s and im not to worried bout it.theres a gy on here with 4.56 gears and 35s and her runing 3000 rpm at 65 i think . so realy i offer u nothing i kinda just wanted to type somthing later
Old Oct 24, 2003 | 11:20 PM
acerockola77's Avatar
acerockola77
If I was racing my truck, I wouldn't be doing it with a strait six..
Old Oct 25, 2003 | 12:49 AM
92 f150300six
o i seen somone elses post and they said they used there truck for racin. and hey whats wrong with the big six for racin o yea there slow i allmost forgot
Old Oct 25, 2003 | 01:16 AM
acerockola77
The big six is a great engine and it's there for the long run, but it's not going anywhere fast.
Old Oct 25, 2003 | 01:28 AM
yellowjeep76
it all depends on how you build it. but of course it will never be as good as a v8.
Old Oct 25, 2003 | 08:02 AM
broncr's Avatar
broncr
I've seen posts of boosted 300's w/ 400HP - maybe more. The six will go as fast as you can afford to. I think I saw an 8.65 quarter mile - that would be fast enough for me...
Old Oct 25, 2003 | 12:03 PM
acerockola77
True true, but since he was talking about a stock 300 w/ 180k on it, i don't think he's gonna be runnin 8s
Old Oct 25, 2003 | 07:13 PM
broncr's Avatar
broncr
Yeah, my mod'd 6 prolly wouldn't turn an 8 in the 1/8 mile. Back to the original post - I noticed today that my 3.50 gears were spinnin' 3000 rpm @ 75 mph, 3300 rpm @ 85 and I don't know what @ 4,000 rpm...
Since gearing is a math thing, going from 3.0 (for example) to 4.0 gears, your rpms (with the same tires) would increase when measured at the same mph (say 75 ). To find out how much, you'd multiply the rpms (2000) by the new gear ratio (in this case 4 ) then divide that number by the old ratio (3 ). So 2000 X 4 = 8000. Divided by three, that's 2666. 3.05's to 4.10's would push that a tad higher, but I don't have a calculator handy, nor the patience to do it by hand. You'd be doin' 'bout 2700 rpm @ 75 with the 4.10's & no other changes ( tire diameter).
I wish I had that 5th speed overdrive - it drops cruise rpm nicely.
jmccracken1214
Nov 27, 2016 04:08 PM
Pepinbilt
Aug 2, 2015 08:04 PM
427 fordman
15
Jul 30, 2012 06:27 AM
GNR22
13
Nov 17, 2011 02:25 PM
frederic.c01
Nov 24, 2009 05:05 AM
