Sponsored by: Real Truck
7.3 peculiar electronic issue
Old Dec 3, 2020 | 08:07 AM
Craig Maffet's Avatar
Craig Maffet
When truck gets warm, the idm cuts out. You can set a minute and buzz test it and the injectors will
come back little by little. Say, after 5 mins 1-4 will fire. Maybe after 10-15 mins they will all fire again.
trying to decide if it’s a Pcm issue or idm issue. Any thoughts?
Old Dec 3, 2020 | 02:07 PM
bwguardian's Avatar
bwguardian
When doing a buzz test, the PCM will send signals to the IDM to fire the injectors. The PCM can be registered through the tachometer movement, and the IDM is registered through the buzz sounds. So watch the tachometer when doing the buzz test to see which it might be.
Old Dec 3, 2020 | 03:53 PM
Craig Maffet
good one! Didn’t think to look at tach and when I tested it. We will try it tomorrow and I’ll post
Old Dec 4, 2020 | 10:01 AM
Model a ford's Avatar
Model a ford
Don’t forget about rocker cover gasket electrical connections!! If they are bad (external or internal) electronic testing is going to be compromised , I would check these first, before going further.
91 Super Duty
50
Oct 14, 2021 11:43 AM
Specializer
Mar 10, 2020 01:19 AM
hotrodtodd
WTB - Parts & other
Mar 2, 2014 11:56 AM
460racer
Jul 4, 2013 02:06 PM
tjc transport
Sep 3, 2006 12:10 PM
