Coolant Leak
Old Dec 2, 2020 | 11:10 AM
burban77's Avatar
burban77
Coolant Leak
The truck is in the garage for the winter and I go out to start it once a week or so and let it run for a while just to keep things moving around.
Yesterday, I got her started and warmed up for a bit then ran in the house to grab something. Came back out 5 minutes later and the temp gauge was reading super hot and then I noticed coolant pouring out from under the truck. There was so much of it I couldn't really tell where it was coming from. I've never had an overheating problem with it.
My first thought was a stuck closed thermostat that built up a bunch of pressure... thoughts?
Old Dec 2, 2020 | 11:17 AM
dubya TF's Avatar
dubya TF
Buy a coolant pressure test kit, top off the coolant (even with just water) and test it with at least 13psi. You should be able to find where the leak is with a flashlight.
https://www.summitracing.com/parts/snn-12270
Old Dec 2, 2020 | 11:45 AM
f5fordgirl's Avatar
f5fordgirl
most likely a freeze plug rusted out.
Old Dec 2, 2020 | 11:48 AM
burban77's Avatar
burban77
Thanks for the replies. I should clarify that the coolant was definitely coming from the radiator... just not sure exactly where on the radiator.
Old Dec 2, 2020 | 12:19 PM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
Pull the radiator and have it repaired, maybe that’s all it needs. Gotta do that regardless. Then, diagnose if you actually have an overheating issue.
Old Dec 3, 2020 | 08:40 PM
Oliver Harwood's Avatar
Oliver Harwood
Don't pull the radiator until you are sure where the coolant is leaking from. The best thing you can do is get as much information as possible. Get a bunch o flight on the radiator and find out where the leak is coming from. If it's coming from the top or bottom tank of the radiator, you are in a different spot than if its coming from the core. Either way, find the leak(s) and don't be afraid to look. I know what it feels like to not want to find out more information because then there's more problems.
Old Dec 4, 2020 | 05:52 PM
john jamieson's Avatar
john jamieson
How old are your hoses? Check the heat hoses as well.
BlueBeauty
Oct 2, 2023 03:22 PM
tigerlady1221
Jan 27, 2016 04:45 PM
Coronado
2009 - 2014 F150
Jan 25, 2015 03:37 PM
brdhouse6
Jun 29, 2011 01:24 PM
4.0 Beast
Dec 22, 2005 05:15 AM
