rebuildin steering column
Old Dec 1, 2020 | 06:09 PM
1browski's Avatar
1browski
Got steering column all pulled apart because I new the turn signal switch needed to be replaced. It was very dirty so pulled it all the way apart, Going to go ahead and replace the upper and lower bearings. C&G ford parts sells c3dz-3517-a as the part for upper and lower bearing. I have found reference to d0az-3517-a as the lower bearing. Not sure if they are the same part or not. My lower bearing is stuck on the shaft and the upper is where it is supposed to be. Does the lower bearing just have to be pressed back on to the shaft? Also I think I am missing lower bearing seal retainer. Do I need this to hold lower bearing in the bottom of the steering column?
Old Dec 1, 2020 | 06:22 PM
1browski's Avatar
1browski
lower bearing stuck on shaft
upper bearing
Thats the cup for the bottom bearing. This is where I thought maybe I was missing that retainer piece.
Old Dec 2, 2020 | 05:22 PM
1browski's Avatar
1browski
Finally found this diagram. I found everything except the 4x4 M/T diagram. I guess I dont need the retainer plate that I was wondering about. I need 2x 3517s which I think are (c3dz-3517-a), 2x 3518s and my turn signal switch(d0tz-13341-b)
Old Dec 3, 2020 | 04:42 PM
1browski's Avatar
1browski
Im glad I research stuff to death and didnt order any bearings listed above. After removing the lower bearing and measuring it, I found that what I thought was right was wrong.
Mine measures the exact same as this bearing. Just need the rubber sleeve to go with it.
1974-1994 Ford Pickup Steering Column Upper Bearing, With Fixed Steering Wheel
Click on above image to view full picture(s)
More Views
Steering Column Upper Bearing - Ford Pickup
Part #: 48-37789-1
Alt Part #: C5SZ-3517-A
Price:
$23.99 ea.
Availability:
In Stock
Fitment:
1961 thru 1979
See applications below for exact details.
  • 1-3/16" OD x 3/4" ID x 1/4" thick
  • 1974-1991 F-series and Super Duty
  • 1983-1993 Ranger
  • 1991-1994 Explorer
My upper bearing is clean and still greased and turns smooth, so its going to stay. None of the bearings I looked at even look like the upper either.
Old Dec 3, 2020 | 08:14 PM
stpackard's Avatar
stpackard
When I did mine I cut the bottom 1/8” or so off the column and installed this aluminum machined bearing mount.
The top bearing I think I got from flashback f100.
https://www.ebay.com/itm/223380119405
Darrellt
May 22, 2017 12:57 PM
blockheadbob
Jul 17, 2005 03:11 PM
