Death wobble? Shaking acceleration.
Old Dec 1, 2020 | 11:27 AM
Zinger351m's Avatar
Zinger351m
When my 1978 f-150 351m idles, everything is fine. When I accelerate it shakes pretty violently the faster I go. If I push in the clutch while driving, and rev it, there is so shaking response, however when I am just driving and push the gas, it starts shaking bad. So bad that it shook my ignition wire loose and I died on the side of the road. It seems like suspension, but I don’t know where. Help!
Old Dec 1, 2020 | 11:38 AM
John89's Avatar
John89
2wd or 4wd?
I would start by checking the U-joints first, primarily as it is pretty easy to do.
Then jack up the front and check for loose wheel bearings/suspension parts.
Old Dec 1, 2020 | 02:01 PM
440 sixpack's Avatar
440 sixpack
Checking the u joints isn't a bad idea but is sounds more like a miss . under load a dead cylinder is much more drastic.
But if it's so bad it's knocking things off you may have something more going on.
StlNavyGuy
Jun 15, 2012 07:34 PM
OleBlue78F250
Feb 16, 2007 12:59 PM
ford390gashog
16
Apr 30, 2006 01:15 AM
fordguy76
Apr 25, 2003 08:09 PM
ford429cu
May 22, 2001 11:19 AM
