rear differential question
Old Nov 30, 2020 | 04:11 PM
Gustavo Morales's Avatar
Gustavo Morales
Hello people... Its possible to change the rear differential in my 2004 F150 2wd using one from the same engine size but 4x4? My differential make a weird noise coming from the ball I believed and I guessing will be better remplace it before try to repair it. Any sugestion
Old Nov 30, 2020 | 04:14 PM
ford390gashog's Avatar
ford390gashog
Yes it is a direct swap.
Old Nov 30, 2020 | 05:06 PM
wheelerfreak's Avatar
wheelerfreak
So long as the gear ratio of the donor axle matches it should be no problem. If the gear ratios don't match it's still a direct swap, your speedo will just be off a bit.
Old Nov 30, 2020 | 05:17 PM
redfishtd's Avatar
redfishtd
There is a metal tag on your bell housing with the info you need .
Old Nov 30, 2020 | 07:23 PM
ford390gashog
Speedo will not be off, the truck doesn't care about gear ratio. The only thing that affects the speedo is tire size diameter. These differentials use a tone ring for the speed sensor.
Old Dec 1, 2020 | 08:42 AM
redfishtd's Avatar
redfishtd
I may be wrong but I thought there is a speed sensor on rear of transmission . When I did my maint on rear end of my 05 I did not see any tone ring or wiring .
Terry Ballard
2009 - 2014 F150
Aug 11, 2020 04:42 PM
Wesley Varn
Dec 5, 2016 01:00 PM
51fordf5
Aug 31, 2013 08:21 PM
proeliator
Offroad & 4x4
May 23, 2001 01:01 AM
