Parking brake disassembling
Old Nov 29, 2020 | 06:48 PM
rm6364's Avatar
rm6364
I need to replace the spring on my 1966 F100 hand brake assembly. I have the handle completely out of the truck. I am having a hard time removing the pin to pull the handle out of the assembly. I have read on here where two firm taps are enough to remove it. I have hit mine several times real hard and it does not seem to budge. Concerned that I may bend the whole assembly doing so. Any thoughts on how to get it out? I have sprayed it with WD40. Do I just need to preserve? Thanks for any suggestions.
Old Nov 29, 2020 | 07:07 PM
resonateur's Avatar
resonateur
...do you see the hole, opposite the pin, in which to put a punch. It shouldn't be too frozen in there and the shaft is very strong. You could also heat it...that should help.
Old Nov 29, 2020 | 11:45 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Third picture down in this post - OM-2859.
Couple things to consider.
1. Make sure your pin punch is smaller diameter than the pin itself.
https://www.ford-trucks.com/forums/1...l#post17457334
2. Ensure the holes in the shaft and the pin line up with the hole in the outer tube. 9th picture in this post.
https://www.ford-trucks.com/forums/1...l#post14688982
3. Ensure it's not completely crusted with rust - rust is a booger.
4. Finally, and this is a recommendation direct from my Dad. Ensure you are smarter than the object you are working on.
He's a bit Mandalorian.
Old Nov 29, 2020 | 11:52 PM
Christmas's Avatar
Christmas
#4 is a must
Old Nov 30, 2020 | 06:21 PM
rm6364's Avatar
rm6364
Thanks for the input. I got it out. Just had to hit it harder. It was #4.
Old Nov 30, 2020 | 06:34 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Or a bigger hammer!?! Hahaha. We knew you could do it. Congrats. I hope nothing bent in the process. It's pretty stout stuff between the tube and the shaft.
Marie P
Feb 3, 2014 12:52 PM
jcstarr
1983 - 2012 Ranger & B-Series
Jan 9, 2007 06:21 PM
John Totten
Aug 30, 2003 10:58 PM
