Washer pump fuse?
Old Nov 28, 2020 | 04:20 PM
Russ31's Avatar
Russ31
Washer pump fuse?
I have an 87 F250 302 and the windshield washer pump just stopped working. I thought I check if a fuse was blown before I dove deeper, but could not find the washer pump listed on the fuse chart. Any thoughts?
Old Nov 28, 2020 | 04:51 PM
My4Fordtrucks's Avatar
My4Fordtrucks
It would be faster to check for power at the pump.
Old Nov 28, 2020 | 05:50 PM
Russ31's Avatar
Russ31
I guess it would at that.
Old Nov 29, 2020 | 09:49 AM
Russ31's Avatar
Russ31
No power at the pump.
Old Nov 29, 2020 | 10:39 AM
My4Fordtrucks
According to the Haynes manual (you have a repair book, correct?) the power comes from the black / light green wire from the ignition switch to the wiper switch. Then the black/ white wire to the washer pump.
Old Nov 30, 2020 | 08:57 AM
Russ31's Avatar
Russ31
Thanks all for the help. I found a chaffed wire that I repaired and the pump is working once again.
Jackiedook
Sep 30, 2019 04:11 PM
Longhirnm1977
Dec 11, 2017 04:38 PM
seth5051
Sep 2, 2015 11:48 AM
jerrytown2001
Jan 6, 2012 11:04 AM
99EdeBauer
Aug 3, 2011 04:24 PM
