Offroad & 4x4
which tire??
Old Oct 30, 2003 | 12:35 AM
Pkupman82's Avatar
Pkupman82
I have heard of guys getting good wear out of BFG mud terrains.
Old Oct 30, 2003 | 02:20 AM
willd's Avatar
willd
If you want really cheap check out hi-tech retreading in the back of 4x4 magazines. I've used their tires on a samurai for 3 years now. The mud tires are same tread as kumho's. I spent 240 dollars for 5 of them. They wear really good, the traction is awesome and they meet my needs perfectly. The vehicle is light-weight and goes slow so I am not concerned about them being re-caps.
Old Oct 30, 2003 | 09:42 AM
eckart's Avatar
eckart
I'd go with the BFG mt. I had a cheap set of bfg look a likes (marshall) on my last truck and they worked ok but you could see the tread going down after ever road trip with 1200 lb camper (200 miles). BFGs have better side walls. My cheep set sliced real easy and I had to replace tires.That can make them expesive in a hurry. Not to say BFG are uncuttable but so far the ones Im running are holding up great. The curent truck is a power stroke and with all the weight on them they are unscard so far. I've only got about 2000 miles on them but close to half is gravel and off road. But at the end of the day you still got to stay with whats in the budget.
Old Oct 30, 2003 | 09:27 PM
ncl's Avatar
ncl
If you want a good affordable mud tire try the Wild Country radial rvt they make 3 different styles of the rvt ranging from really agressive to a moderate tire. Also try general grabber m/t,buckshot mudder, cooper tire or courser, mastercraft even makes a tire, and you can get Super Swampers for a decent price depending on size, My uncle just picked up 4 TRXUS MT 31/10.50 15 for $105.00 a tire
Old Nov 4, 2003 | 10:17 PM
opporll's Avatar
opporll
The wild countrys are a great tire for your off road to on-road ratio. and the rubber compound in them seems to last forever, im not sure on the aggresivness of the tread on my wild countrys, but the only area they seem to lack in is thick mud. the best thing about them is that they are cheap
Old Nov 5, 2003 | 12:48 AM
kevinrf250's Avatar
kevinrf250
We have had tried two sets of wild countries and they wear out very fast the current ones have around 18,000 miles and are worn out, and yes they are rotated every 5,000 miles and at the correct pressure. I just purchased a set of Big O Big Foot X/T's and so far they are great, pretty agresssive tread but still sutible for the road. Hope they work out.
Old Nov 5, 2003 | 10:12 AM
mattsf250's Avatar
mattsf250
another tire tossed into the mix here, and what i just ordered today.....the Nitto Terra Grappler. i priced the big o tires, about 760 out the door.... the nittos in the same size, 285/75/16 are going to be 535 to my door, yet still need mounting and balancing....so about another 50-60 bux.
i got these for the snow/ice traction, i do little mud (hard to find), but ice and snow are common where i live. the nitto has a ton of sipes, deep too, not like the bfg T/A's! also, they are in between a mud and a/t as far as tread design goes....
will report back once i get them in the snow, and some mud....
best price, and free shipping came from tires.com for me, your milage may vary.....
good luck!
Old Nov 6, 2003 | 01:31 AM
mrwizard's Avatar
mrwizard
Had the Wild Country RVT traction (the really aggressive ones) tires on my truck when I bought it. They were the worst tires I have ever had the misfortune of having on my vehicle. I now have the Big O Big Foot AT's. I love them. I have put them through every kind of terrain here in the last few weeks hunting, and have only been able to have them loose traction once. That was when I was backing up and ended up planting my receiver hitch in the mud. They have been totally impressive over rock, dry dirt, mud , snow, you name it they work great. Not to mention they work great on the street.
Old Nov 6, 2003 | 03:01 PM
carlos694x4's Avatar
carlos694x4
Radial Buckshot mudders are a Cheap priced tire and they look pretty aggressive,
http://www.d-90.com/tire/denman.html
Old Nov 7, 2003 | 09:14 AM
marriedguy1's Avatar
marriedguy1
I forgot about the Nitto All terrains. I have some on my wife's Expy and they are a very good tire. I got 4 of them mounted, balanced, valve stems, tax, and Discount tire road hazard free replacement certificates for $645. 285/75/16 was the size by the way.
Old Nov 8, 2003 | 06:26 PM
dyarumian's Avatar
dyarumian
how bout Mud kings they'r made by BFG
Old Nov 8, 2003 | 08:00 PM
linx's Avatar
linx
I have a set of Super Swamper SSR's. Quiet on the highway, with the legendary Super Swamper TSL tread patern.
Really nice radials.
Old Nov 8, 2003 | 10:09 PM
  #28
Pkupman82's Avatar
Pkupman82
I have two sets of rims for my 84, the aluminum set with the ATs are on the truck right now. I am thinking about getting a set of 31x11.50 Super Swamper LTBs to mount on the steel whitespokes for off roading. They only go for 94 bucks a piece.
Old Nov 9, 2003 | 12:10 PM
  #29
bocephus_3349's Avatar
bocephus_3349
if you want cheep and good go with interco tire's. go with the truxus( i might have spelled that wrong) they are pretty well priced for the at's and mud. my buddy runns the at's and got 45,000+ miles out of them
Old Nov 10, 2003 | 01:46 AM
  #30
Pkupman82's Avatar
Pkupman82
Yep I heard Intercos wear pretty good on the street even though they are made for mud and sand.
