Strange noise recently
Old Nov 27, 2020 | 04:25 PM
Back2Gas?'s Avatar
Back2Gas?
Hi all,
I have a 2000 F250 7.3 automatic with under 150k miles, an old skool wicked wheel, and have recently been hearing a weird buzzing/resonance sound under certain conditions like lifting the pedal while under some load at around 1600 to 1800 rpm. It sounds like turbo noise to me, but a quick inspection of the compressor wheel shows it to be tight, not rubbing the housing and no loose blades.
Any ideas or further questions or things to look for?
Or am I just being paranoid and looking for a winter project? lol
Thanks in advance...
Old Nov 27, 2020 | 10:21 PM
udsuth78's Avatar
udsuth78
Ever done a boost pressure test? Maybe you're hearing a boost leak. Can't hear it over engine noise, but once you get it spooled up and let off, engine quiets down enough to hear.
Old Nov 28, 2020 | 03:12 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
A video with sound might help a lot.
Til then, got a boost gauge?
As far as winter project, a modern billet turbo wheel will solve all your truck and marital problems!
Old Nov 28, 2020 | 09:19 AM
Back2Gas?'s Avatar
Back2Gas?
Yes I have done a boost pressure test before. We found a small leak in the intercooler and welded it up. My boost gage works great and all seems normal with up to 24 psi towing up a grade in 3rd gear at around 2700 rpm on my hydra 25hp tow tune.
I'll try and add a sig line...
Old Nov 28, 2020 | 09:21 AM
Back2Gas?'s Avatar
Back2Gas?
Test for signature info...
Old Nov 28, 2020 | 10:17 AM
RacinJasonWV's Avatar
RacinJasonWV
Signature is working but won’t show on a mobile device unless you “request desktop site”.
You may have already known this info, but wanted to share because it took me a while to figure out why I couldn’t see the signatures.
Old Nov 28, 2020 | 10:37 AM
Back2Gas?'s Avatar
Back2Gas?
Good to know. I usually sit at my PC for stuff like this though...the small phone screen frustrates me sometimes. lol
Old Nov 28, 2020 | 05:44 PM
Back2Gas?'s Avatar
Back2Gas?
I made a recording that should provide good audio of the noise.
How do I share it?
Like this?
https://photos.app.goo.gl/DjLdLJCV7qDWJjzz9
The last few seconds clearly contains the buzzy resonance sound.
The first cycle is the normal sound, the second cycle ends with the noise.
Old Nov 29, 2020 | 10:21 AM
Back2Gas?'s Avatar
Back2Gas?
Added pic to sig, I think...
Anybody listen to the noise yet?
Old Nov 29, 2020 | 01:53 PM
FinnishStroker's Avatar
FinnishStroker
Sounds like exhaust resonating.
Dual outlets makes exhaust vibrate x 2
Checked hangers allready?
Old Nov 29, 2020 | 02:35 PM
Back2Gas?'s Avatar
Back2Gas?
Good idea.
​​​​​​​I didn't check the hangars, but I did check all the plates and stuff around the exhaust. Maybe I should take the rubber mallet all along the exhaust.
Old Dec 7, 2020 | 09:12 AM
Back2Gas?'s Avatar
Back2Gas?
So I finally got check more stuff for looseness yesterday. I could not find a culprit, everything was tight.
I guess I'll just drive with my fingers crossed and hope for no surprises...
Old Dec 13, 2020 | 09:32 AM
Back2Gas?'s Avatar
Back2Gas?
Do leaky up pipes make noise?
Old Dec 13, 2020 | 11:01 AM
RacinJasonWV
They can. Tick tick tick was my experience... wait that was the manifold leak.
Old Dec 15, 2020 | 10:45 AM
Back2Gas?'s Avatar
Back2Gas?
Thanks, guess that's not it...
