Welding SS exhaust pipe
Old Nov 26, 2020 | 03:43 PM
moejr's Avatar
moejr
Can I use my MIG welder, that is set up with .035 mild steel, to weld SS exhaust pipe? Any Issues besides rust forming on the weld joint that would be a concern?
Old Nov 26, 2020 | 04:00 PM
hobohilton's Avatar
hobohilton
Without more info I'm going to say... No, you can't use your MIG welder.
In general, stainless steel must be welded with some form of "shielding gas", preferably argon that keeps oxygen away from the weld puddle. Now, under very good conditions you can weld stainless steel with a MIG set up if you are pushing stainless steel filler wire and shielding with argon.
A good question.
Hobo
Old Nov 26, 2020 | 04:38 PM
ford390gashog's Avatar
ford390gashog
You can use ER70S with 75/25 gas a weld it just fine. Be warned it will rust and the parent metal is prone to fracture in high stress.
Old Nov 26, 2020 | 07:10 PM
moejr's Avatar
moejr
The wire in the welder now is copper coated 0.35, I'll check the spool tag but I'm sure the wire is for mild steel applications. The shielding gas is 75Argon / 25CO2.
Old Nov 26, 2020 | 07:49 PM
hobohilton's Avatar
hobohilton
You are getting ready to learn a lesson.... and it has nothing to do with welding.
Hobo
Old Nov 26, 2020 | 10:05 PM
ford390gashog
Your all set, it will weld just fine.
Old Nov 27, 2020 | 08:27 PM
moejr's Avatar
moejr
I got some scrap 2-1/2" SS pipe......will lay a few tacks down and see how they look. Thanks for your input guy's.
Old Nov 27, 2020 | 11:14 PM
trz1000's Avatar
trz1000
As mentioned it will weld just fine with mild steel wire and c25 but will rust at the weld. You can get stainless wire and trimix at the welding store but be ready for some sticker shock.
Old Nov 28, 2020 | 07:38 AM
tjc transport's Avatar
tjc transport
i ain't rite
your mig will weld it, but to do it properly you will need a roll of stainless wire and a bottle of argon gas.
Old Jan 24, 2021 | 03:37 PM
moejr's Avatar
moejr
Finally got around to welding up a steel to SS pipe......worked out fine using .035 steel wire IMO. Would definitely get the SS wire if I was to weld up a big project with SS material.
Old Jan 30, 2021 | 09:28 PM
Beechkid's Avatar
Beechkid
I use stainless steel rod and my oxy-acet torch!
Old Jan 30, 2021 | 09:34 PM
hobohilton's Avatar
hobohilton
________________
What kind of flux did you use ?
Hobo
Old Jan 31, 2021 | 12:35 PM
Beechkid's Avatar
Beechkid
Originally Posted by hobohilton
________________
Hobo
I had some powdered brazing flux "laying around here"... just used a stainless steel brush, sprinkled a bit on the pipe & the end of the rod and we were good!
1980302windsor
Mar 19, 2011 10:25 PM
heygibb
Aerostar
Jun 29, 2010 12:43 AM
killforfood
Dec 10, 2008 11:24 AM
reg1952
Nov 11, 2008 12:00 PM
Uglyhat
Exhaust Systems
Oct 19, 2005 01:48 AM
