One Side?
Old Nov 26, 2020 | 06:47 AM
TrixR4kids's Avatar
TrixR4kids
One Side?
I pulled my Power steering pump, bracket, and steering gear yesterday in preparation for the saginaw upgrade and a rebuilt steering gear.
I already purchased new shorty headers that I wanted to put on since I have a tick on the passenger side.
Will I be able to swap just the one side while I am in there and drive the truck until I get around to the passenger side? I plan on doing leveling springs and new shock towers at the same time as I do the passenger side.
Old Nov 26, 2020 | 08:08 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Yes. Shorty headers will bolt right up the the factory “Y” pipe.
Old Nov 26, 2020 | 08:11 AM
TrixR4kids's Avatar
TrixR4kids
Thank you, so nothing to worry about as far as tubing for smog or anything that wouldn't hook up to the new header?
I'll spray the bolts down with some penetrant again today for the break out tomorrow. Fingers crossed!!
Old Nov 26, 2020 | 08:21 AM
My4Fordtrucks
Do you have air in head or air in manifold? Do you currently have any air injection tubes on the driver’s side? The EGR on a 5.8L is on the passenger exhaust manifold. There shouldn’t be anything plumbed into the driver’s side that I’m aware of.
Old Nov 28, 2020 | 02:41 PM
TrixR4kids's Avatar
TrixR4kids
You are 100% correct. Got it done this weekend Only took about an hour and a half to swap out the manifold. So pleased that none of the bolts snapped off.
The nuts for the engine bracket were past corroded and gone, but a torch made short work of that.
My only question is in regards to the connection at the y-pipe.
I got the Fel-pro gasket set for the headers. It came with two donuts and two flat oblong gaskets. The original manifolds didn't have any gaskets were it met the y-pipe. Do I just shove those donuts in there and crank her down, or are these for a different application?
Old Nov 28, 2020 | 03:42 PM
My4Fordtrucks
Should be a ball and socket joint? No gasket/ donut needed.
Old Nov 28, 2020 | 04:17 PM
TrixR4kids's Avatar
TrixR4kids
You are correct again. That is what I did. Sometimes it's just nice to have that confirmation on my assumptions.
Thanks!
Old Nov 28, 2020 | 04:49 PM
My4Fordtrucks
Hope the passenger side is just as easy. Good luck.
JMyers0901
Mar 26, 2013 11:22 AM
mjshagnasty
Jul 19, 2011 06:38 AM
lilpro
Aug 14, 2006 05:42 PM
