Alternator conversion
Old Nov 25, 2020 | 09:47 PM
josephguldan's Avatar
josephguldan
I'm sure it already be discussed, can someone please direct me to a thread on converting my 49 F1 V8 to an alternator. It has already has been switched to a 12 volt neg ground system with a generator but I would like to switch to an alternator
Old Nov 25, 2020 | 10:11 PM
Mixer man's Avatar
Mixer man
Originally Posted by josephguldan
I'm sure it already be discussed, can someone please direct me to a thread on converting my 49 F1 V8 to an alternator. It has already has been switched to a 12 volt neg ground system with a generator but I would like to switch to an alternator.
This subject has been discussed ad infinitum ad nauseum. Sounds like the hard part has already been done. So the next question is, do you want an alternator that looks like a generator and fits in your original bracket, or do you want an alternator that looks like an alternator and requires a special bracket?
Old Nov 25, 2020 | 11:04 PM
Scotty's 52 F3's Avatar
Scotty's 52 F3
A lot of people use a GM 1 wire alternator. You can use an early Ford and keep an external regulator in place. Old MOPAR alternators look pretty good. You just need the right adapter bracket and wire according to the type you choose. Lots of options.
Old Nov 26, 2020 | 03:12 PM
ALBUQ F-1's Avatar
ALBUQ F-1
It is also possible to mount a GM alternator with a little modification using the stock generator mount. You can drill a locating hole in the GM alt that fits it in the dowel in the stock mount. You just have to get it in the right place, and revise the strap to fit around the larger alternator. The pulley from your generator will work on the GM alternator.
Old Nov 27, 2020 | 03:38 PM
CharlieLed's Avatar
CharlieLed
Powermaster 82021-2 PowerGEN 1949-53 Ford Flathead Alternator, 12-Volt (speedwaymotors.com)
lewiscrouse
Apr 28, 2020 06:25 PM
sciondude09
Mar 15, 2009 05:59 AM
njsamurai
Aug 14, 2006 12:15 PM
