Alternator Upgrade
Old Apr 26, 2020 | 05:54 PM
lewiscrouse's Avatar
lewiscrouse
Alternator Upgrade
Anyone put an upgraded alternator on their slick? If so, what'd you put on there?
Old Apr 27, 2020 | 11:33 AM
FordsOnlyGarage's Avatar
FordsOnlyGarage
Check out Summit, I have used these in the past for a Mustang when I installed an MSD box and better headlights...
Old Apr 27, 2020 | 06:57 PM
BobbyFord's Avatar
BobbyFord
I have a 3-wire GM alternator on my 63, generator light even works. Can’t remember how I did it, it was 20+ years ago.
I put a 3G Mustang alternator on my ‘72. Super easy. I used a Painless 3G harness from Summit racing.
Here’s a good step by step from Hotrod...
https://www.hotrod.com/articles/inst...r-older-fords/
Old Apr 28, 2020 | 04:15 PM
lewiscrouse
Thanks y'all, I'll look into those
Old Apr 28, 2020 | 04:34 PM
chiefdave's Avatar
chiefdave
I've used Alterstart Systems in Dallas twice. 6v +ground for my '49 Ford and a 60 amp to replace the generator on my '62. Both work well and the staff will take all the time needed to make sure you get what you need.
Old Apr 28, 2020 | 06:25 PM
6t6merc's Avatar
6t6merc
The HOTROD article is pretty good.
The Galaxie 352 pictured has a two-sheave alternator pulley. These pulleys are not too often found on passenger cars but they are a very common option on the truck 352. The 3G can cause the belt to slip and squeal without one.
Eric
Irish19614x4
Sep 9, 2019 10:36 AM
TimothyJames
Electrical Systems/Wiring
Aug 28, 2016 04:29 PM
kbarbee95
36
Jul 17, 2015 12:33 PM
pstrokelover
May 21, 2014 05:36 AM
slapshotjn
Sep 5, 2002 08:09 PM
