Okay, so the pros on this forum have talked me out of moving my gas tank on my '66 2WD F-100 ... my next look is brakes. I want some better stopping power and have considered one of the drum to disk conversion kits. My questions:
There are several kits I've found ... is one the stand out best? Left to myself I'd go with the MP Brakes kit ...
Should I do just the front or all four wheels?
While I know it is a lot of steps, the videos I've found make it look fairly straightforward .... is this the case?
Honestly do a search for "disc brakes" on here. You'll have PLENTY of reading material as this is another constant rotational topic. Really it depends on your mechanical ability and budget.
I wouldn't waste the money on the rear, the back brakes don't do much to stop the truck anyway, most of the work is done by the fronts. The front will be a huge improvement though.
So am I. I have a 79 f100 parts truck that would be a perfect candidate of a complete front end swap. The master and booster look almost new. The truck has everything for a conversion. As mentioned read the plethora of info regarding this on the site. I did the conversion on my truck and it was fairly easy. Email me if interested chircolandinc@gmail.com
Many people , after getting their brake system into good working order, find that they can live with it. That means drums that are within spec, new shoes/wheel cylinders,new hardware, proper adjustment., and a good functioning hydraulic system. Since I drive mine, I’d guess, pretty tamely, and much the same way someone would have in 1966, I am fine with stock brakes.
IF OP is planning to get the parts out of a boneyard, which is my suggestion, then he probably should get all the power steering stuff at the same time because the direction he's going, that's next.
I was thinking bigger than the spindles. Like booster and M/C, distribution valve, brakes hoses and related clips, etc. Not sure swapping spindles will result in a "correct" setup with no other changes.
Bishicka, Are you aware of some of the details to put this together in order to attain optimal results? Don't take that as criticism, we don't know you. You have 14 posts and we don't know if you are dipping your toe into a world that you have never been interested looking into before now, or are well studied.. Either way, good on you, you have a nice looking truck.
The CPP kit I posted above is what I''ve got installed on DJM drop beams. His truck being a 66 is what kinda limits choices on how to tackle the "problem". I agree that a donor truck is the absolute best way. Factory parts, nothing exotic and easy to assemble. I just didn't have that option when I did all my research on this topic. Knowing what I know now- I'd go with a Wilwood kit just for the higher quality 6 piston calipers which would make rear discs even MORE unnecessary.
No offense taken. I'm what we would have called in the Army a FNG ... in sports, a Rookie. I can handle a MC / Booster replacement. I can do hoses and clips and I've changed rotors and pads on cars before. The YouTube videos for "change front end" look well beyond my skill.
I bought this truck because I've always wanted an old Ford, and because I've always wanted to indulge my desire to turn a wrench. I'm recently semi-retired and now have the time. I don't mind putting the truck on stands all winter to work on it (I live in MA where it is miserable all winter) and I have the guts to wade in a little over my head, but smart enough not to get myself in too deep. At least I hope I am!
I appreciate all the comments, pushback and I'm open to the critique, when it comes!
