Tire Pressure Question
Old Nov 23, 2020 | 09:08 AM
jbwardfamily's Avatar
jbwardfamily
Hi all. I have a ‘19 F350 Powerstroke Crew Cab short bed XLT. I put 35-12.50-18s BFG AT/KO2s on it. The pressure on the tire says 65psi Max, but the dealer said the rear tires should be at 80 no matter what the tire says. Is that right? I thought the tire psi recommendation was the rule. I tow a 11k lb travel trailer and golf cart with about 2500 lb total bed/tongue weight. I only had it checked because the TPMS sensors tripped on both rear tires.
Old Nov 23, 2020 | 09:17 AM
jdk1's Avatar
jdk1
Go by the tire rating, not the truck sticker, because you can put any tire on a truck. That truck should have E rated tires, which should hold 80, but if the tires are not E tires, then go with what the sidewall says. Also, most people with tires that hold 80 don't keep that much air in them in unless they need it for load capacity.
Old Nov 23, 2020 | 09:26 AM
ford390gashog's Avatar
ford390gashog
Your going to have to change the TPMS in forscan if you want to run a lower rated tire.
Old Nov 23, 2020 | 09:33 AM
jbwardfamily
Does that have to be done at the dealer? They did not even offer that option.
Old Nov 23, 2020 | 09:38 AM
Ding126's Avatar
Ding126
My F 350 sticker shows 60 psi in front and 80 psi for rears. I run empty with 50psi in front and 65-68 in rears. No TPMS lights
As for your tires, my Toyo MT E rated tires had a max air of 60 so that's what ran them at... I would not exceed the tire manufactures ratings IMO
Old Nov 23, 2020 | 09:41 AM
HRTKD's Avatar
HRTKD
If you get the FORScan software and the required OBDII adapter you can program it yourself. Otherwise, the dealer _may_ do it for you, at their labor rate.
It sounds like you have a D rated tire on a truck that came with an E rated tire. The dealership may balk at making any changes for you because of that.
Old Nov 23, 2020 | 09:44 AM
WE3ZS's Avatar
WE3ZS
Yes, go by the tire rating and don't inflate above the sidewall max ratings. Better yet go by the scaled axle weights and a tire inflation weight table provided by the tire manufacturer, that's the best course of action to get the exact right inflation for the load.
I disagree that any "E" rated tire (an outdated rating system, but for this discussion I think everyone understands the intent) should have an 80 PSI rating. The max inflation is a function of the contact patch vs the intended weight carrying capacity, a larger, wider tire (like the OP stated that he has) will have a lower max pressure due to having more square inches in its contact patch, in this case it maxes out at 65 PSI. My 305/70R18 (35.28X12.8) Nitto Duras, which are "E" rated are the same 65 PSI max inflation but have a higher weight rating than the stock 265/75R16 tires that they replaced, even at that lower pressure.
The OP's dealer, who stated the tires needed to be at 80 PSI no matter what the tire sidewall stated is a dangerous idiot.
Old Nov 23, 2020 | 09:46 AM
jbwardfamily
that’s what I was thinking. I’ve been running 55 on the fronts and 65 on back. I’ll go back to that and just deal with the TPMS lights until I can get them reprogrammed. The tires are E rated.
Old Nov 23, 2020 | 10:26 AM
Kellem's Avatar
Kellem
Yes, my 35" Dynapro's have a higher weight capacity than stock with a 65# max psi, very common in an E rated 35" tire.
I actually performed a chalk test on garage floor and run 47 in front and 40 in back empty.
Albeit this is a Ram 2500 5.7......while I'm waiting on my F250 to arrive.
Old Nov 23, 2020 | 10:29 AM
acadianbob's Avatar
acadianbob
I wonder what the load rating is on your tires given the 65PSI max. You should check versus a legitimate Load Range E tire. Your payload capacity may be compromised.
Old Nov 23, 2020 | 11:17 AM
Killer-Bimmer's Avatar
Killer-Bimmer
Do these trucks not have a TPMS teach function? My cars i just hold down the TPMS button for a few seconds and then it goes into teach mode, after about a mile it sets to the new pressure? The TPMS should just be a +/- range of the set point.
Old Nov 23, 2020 | 11:57 AM
matt167's Avatar
matt167
Fords all use sensors at this point. Cars with buttons are generally using wheel speed sensors and the ABS system..
An Autel TS508 tpms scanner can set the tpms threshold as well. I do it about daily for various trucks
Old Nov 23, 2020 | 12:02 PM
HRTKD's Avatar
HRTKD
I have an Autel TS601. I haven't looked for it, but I wonder if mine can set the threshold also. What I really want is a way to adjust the reported PSI from the sensor. I have a set of sensors that consistently report 3 PSI below what a number of my digital gauges say.
Old Nov 23, 2020 | 12:08 PM
matt167's Avatar
matt167
601 may have it. On a 508 it's under "Set TPMS Threshold" in the main advanced screen for most any Ford/Chevy/ Dodge product. It does not work on most dodges as it creates error codes. Anyway, the sensors themselves are almost never perfectly accurate, and they will display whatever they display but that firmware is embedded within the sensor.
Old Nov 23, 2020 | 12:19 PM
HRTKD's Avatar
HRTKD
Thanks Matt! Reps sent.
