Computer Fried?
Old Nov 23, 2020 | 07:36 AM
craig564's Avatar
craig564
Computer Fried?
I have a 2010 F150 Super Crew, 4.6L 3V, 2WD, 5.5' Bed, this past week my TPMS kept randomly flashing on my dash, along with the traction control light. Today it started doing it again, but along with those two symptoms, as soon as the dash started flashing, the air conditioning stopped blowing cool air and the temp on the center dash ran up to 125 degrees (i got a pic when it was 111), then the 125 degrees went back down to the correct temperature of around 80. Any suggestions? Is the computer fried?
Old Nov 23, 2020 | 09:54 AM
Lime1GT's Avatar
Lime1GT
First you have to check for Codes and list them so the forum has a place to start. It could be as simple as a failing abs sensor. You may also want to check the age of the battery, condition of battery cable clamps and have it load tested.
Old Nov 23, 2020 | 10:04 AM
craig564's Avatar
craig564
Brand new battery last week, I ran my code reader on it and O'Reilly's ran theirs, the only codes are for the O2 sensors (which have been on there for a while)
Old Nov 23, 2020 | 02:16 PM
Newnavowner's Avatar
Newnavowner
I'd suspect the new battery. Try another battery and see if it goes away.
Old Nov 23, 2020 | 06:29 PM
craig564's Avatar
craig564
I'm curious why you would think it's the battery. It's putting out the correct volts/amps. All of the electrics work and the truck starts fine.
Old Nov 24, 2020 | 08:49 AM
Newnavowner
Simply because the problem happened shortly after the new battery.
hotrodford_88
Aug 18, 2017 03:59 PM
gapperF150
2009 - 2014 F150
Jul 1, 2010 08:33 PM
choochoof150
Jul 13, 2009 12:39 PM
eco
Aug 20, 2006 10:20 AM
high ho silver
Jun 29, 2006 12:52 PM
