T98 To sbf help!!!!
Old Nov 22, 2020 | 06:56 PM
Demarcus454's Avatar
Demarcus454
T98 To sbf help!!!!
I have a 63 f100 I'm doing i took the 292 out and bought a 302 crate motor well the guy wants to keep the T98 no other option i found a sbf bellhousing that bolts to the T98 what option do I have for rear mounting on the tail shaft and what options do I have as far as clutch pressure plate and pilot bushing
Sbf bellhousing to T98 trans
Old Nov 22, 2020 | 08:12 PM
Red60's Avatar
Red60
I am interested in the answer too. My research came up short thus far...
Old Nov 23, 2020 | 06:42 AM
2dwoods's Avatar
2dwoods
I did same swap but 351 I put a t19 in so I kept my granny 4speed and the 19 is fully synced it also came with hyd.clutch so no more linkage
Old Nov 23, 2020 | 06:38 PM
Demarcus454
yeah I found this Bellhousing on Ebay and it bolted right up I've ordered the rear mount for an older model big Ford truck that uses the rear mount setup I'm just going to make a crossmember for it then hopefully I can figure out linkage and clutch
Old Nov 23, 2020 | 06:40 PM
Demarcus454
what did you do for clutch and pressure plate setup and flywheel??
Old Nov 25, 2020 | 07:55 AM
2dwoods's Avatar
2dwoods
its just the 4 speed flywheel the automatic is diff. so i took 4 speed and all from a 85 f350 hydro clutch and all
Demarcus454
Nov 22, 2020 06:56 PM
Ty Kampen
22
Jan 16, 2017 03:17 PM
72 Charger
Aug 3, 2015 09:18 AM
CShroom
Jul 6, 2009 08:38 PM
