Hello I am trying to unlink my fobs from the easy recall. The procedure in the manual says to hold the seat position then when beeps press unlock to unlink this does not work, but click lock to set it of course does.
If I do a Module Reset on the SMM with Forscan do you think it will clear these out? If not how do you properly clear them? I have found two articles on Fords website and neither works on my 2022 F-250.
I'm tired of having to reset lumbar, mirrors and seat position every time I get in my F350. As a data point, the seat moves to a position, just not the one I have saved. It WILL move to position 1 if I press the button on the door. It WILL NOT change the lumbar setting or mirrors.
I've tried overwriting, unpairing via unlock and am considering unplugging the module under the seat.
