ATF as fuel additive?
Old Nov 20, 2020 | 11:19 AM
Overkill2's Avatar
Overkill2
The older engines weren't called oil burners for nothing.
Old Nov 20, 2020 | 05:04 PM
hogryder007's Avatar
hogryder007
Use of ATF in diesel fuel as beneficial to injectors is anecdotal at best. Just because the OP used ATF and had no injector trouble for 235K does not mean the ATF is responsible for his good fortune.
Old Nov 20, 2020 | 07:55 PM
jollyrogr's Avatar
jollyrogr
Use of 2 stroke oil or ATF to fix a sticky injector is not anecdotal. It was common practice back in the day and it did work.
Old Nov 20, 2020 | 08:58 PM
Iowa Ford's Avatar
Iowa Ford
I second the motion !
Old Nov 21, 2020 | 05:24 PM
351Cleveland C4's Avatar
351Cleveland C4
My '11 is at 272k miles. It's only ever had fuel in it. And on RARE occasions, a bottle of Lucas fuel additive.
The new systems are made for new fuel.
Don't put anything else in it
Old Nov 21, 2020 | 06:33 PM
Painted Horse's Avatar
Painted Horse
Ad they were mechanical injectors back then Or maybe a HUEI injector. But not todays Common Rail systems
Old Nov 23, 2020 | 09:11 AM
jollyrogr's Avatar
jollyrogr
True, but I also know it would help injector balance rates on early generation duramaxes (common rail, pre-emission)
Old Nov 23, 2020 | 12:55 PM
mjs2011's Avatar
mjs2011
I'll agree with this statement as well. ATF is also helpful for freeing up stuck metering valves in the old Bosch rotary injection pumps used in Ford IDIs before the powerstroke.
ssolid
Jul 18, 2014 08:13 PM
Tym
Sep 22, 2010 10:10 AM
mravetto
Sep 12, 2009 06:54 PM
vypr
May 24, 2007 10:29 PM
buckshot047
Dec 29, 2006 06:16 PM
