Transfer Case Fluid
Old Nov 18, 2020 | 04:53 PM
EllieMae94's Avatar
EllieMae94
Transfer Case Fluid
What are you guys using for transfer case oil? This is for the BW 1356 in my ‘94. Ford original spec was for Mercon, and while Mercon V replaced it and is what should be used in transmissions, apparently it is not to be used in transfer cases. What gives?
Old Nov 18, 2020 | 05:03 PM
904Jeremy's Avatar
904Jeremy
Who said to not use Mercon V ??
Old Nov 18, 2020 | 05:06 PM
EllieMae94's Avatar
EllieMae94
I guess from Ford. I have some Motorcraft Mercon V I use for my 4R70W and on the back of the bottle it says not to use in transfer cases.
Old Nov 18, 2020 | 05:24 PM
904Jeremy's Avatar
904Jeremy
They’re getting kinda carried away with the right and wrong oils to use in transmissions and transfer cases, they even contradict themselves on the bottles, I was able to find a bottle of DEXRON iii/Mercon from an old failed project and used that to get my new project about 10 miles to my house...maybe I need to drain it ASAP
Old Nov 18, 2020 | 05:53 PM
EllieMae94's Avatar
EllieMae94
It's confusing me sometimes what Ford does. The Dexron/Mercon might be totally fine to use. So the Motorcraft bottle of Mercon V says not to use in transfer cases while the bottles I have of Supertech Mercon V and Valvoline Mercon V has no mention of not using in transfer cases. Maybe it doesn't matter.
Take a look at the Motorcraft bottle, 3rd bullet down:
Old Nov 18, 2020 | 06:14 PM
aquartlow's Avatar
aquartlow
FWIW, I use John Deere Hygard j20c hydraulic fluid. I recently opened up the transfer case of my late son's '95 f150 to seal the halves and it looked almost spotless inside.
Old Nov 20, 2020 | 05:41 AM
gaj0137's Avatar
gaj0137
Below is a video about Mercon V in transfer cases. Ford XL-12 Transfer Case Fluid is now recommended in transfer cases where MERCON ATF was previously recommended.
Old Nov 20, 2020 | 06:06 AM
JJF20's Avatar
JJF20
I just drained my Tx case and read your post. Good catch.
Here’s what I found:
https://www.fcsdchemicalsandlubrican...id=120&pid=426
https://www.fcsdchemicalsandlubrican...id=120&pid=425
JJF20's Avatar
JJF20
https://youtu.be/F7gKtqkuhmU
Good video, thank you for posting it up.
Old Nov 20, 2020 | 06:23 AM
EllieMae94's Avatar
EllieMae94
Thanks guys. I ended up using Valvoline Full Synthetic Transfer Case Fluid that calls for Ford XL-12. Also as linked above, Mercon LV is now to be used as XL-12 no longer exists.
In summary, our trucks use Mercon V in the automatic transmissions and spec XL-12 or Mercon LV in the transfer cases.
Old Nov 20, 2020 | 07:33 AM
My4Fordtrucks's Avatar
My4Fordtrucks
I have been using Valvoline Dexron III / MERCON in my transfer cases for years without any issues.
PatrickStapler
Sep 10, 2020 07:12 PM
Skauber
18
Apr 2, 2017 07:45 AM
epoppe4
Apr 29, 2016 03:45 AM
B1GKAHUNA
Mar 25, 2007 10:27 AM
ddoyle777
2004 - 2008 F150
Feb 5, 2005 09:17 PM
