wheel spacers
Old Nov 16, 2020 | 01:37 PM
JJray's Avatar
JJray
wheel spacers
I've looked on here for my answer and haven't been able to find what I'm looking for. i have an 85 f250. I'm looking to put different rims and tires on, however they the back spacing is less than the current rims on it now. is it bad practice to run a 1-2 inch spacer on heavier trucks? I'm not a fan of them to begin with but my options are limited right now. any help would be appreciated. thank you.
Old Nov 16, 2020 | 02:10 PM
Olds64's Avatar
Olds64
JJray, I'm not a fan of wheel spacers. However, they are used from time to time on pickups. Here's a good thread:
https://www.ford-trucks.com/forums/1...l-spacers.html
If you can, get wheels with the proper backspacing, offset, etc. before buying spacers.
Old Nov 17, 2020 | 07:02 AM
FuzzFace2's Avatar
FuzzFace2
Me I would not run a 1" spacer on anything I owned and never on a 250+ truck.
I do have 1 car with a 1/4" spacer so the after market wheel clears the brake caliper but the dealers did this back in the day on the same cars.
Dave ----
Old Nov 17, 2020 | 02:38 PM
BlueWhiteFord's Avatar
BlueWhiteFord
1-2 inches are pretty hefty. I understand where you are coming from, but I would also warn against it. It might work, BUT if there is a problem you are going to have a hell of a time. So I would also strongly advise against it.
Old Nov 17, 2020 | 06:12 PM
FuzzFace2's Avatar
FuzzFace2
Also with the wheel / tire out farther than factory the stress put on the wheel bearings / hubs and suspension parts also goes up.
Dave ----
Old Nov 22, 2020 | 12:38 AM
DarkOverCast's Avatar
DarkOverCast
The only spacers id run would be steel ones, seen too many aluminum ones fail. But they fetch roughly 600-1000$ a set...which will go real far towards a set of correct wheels.
Stahl, and arrowcraft are a couple brands that come to mind.
Jesses1999f250
Feb 9, 2015 08:27 PM
sturgial
Jan 3, 2014 09:38 AM
shano63
Jan 27, 2013 01:10 PM
ibminnie4u
Jul 12, 2009 05:06 PM
blackfox
Sep 10, 2007 05:45 PM
