Ok...heres what i need to know. I need a liquid thats readily available and cheap that will conduct electricity. Before i just go start buying stuff, i was hoping someone might have an idea for me. I HATE COLLEGE PROJECTS. LOL
Hi, not a chemist but maybe this helps. Not all liquids conduct electricity. Pure distilled water for example does not conduct. In order for an electric current to be conducted, some charged mobile carriers such as free electrons (as in a metal) or free ions must be present. A solution which contains free ions will conduct electricity. Strong electrolytes are thought to dissociate completely into ions. Most salts such as NaCl and some acids such as HCl and HNO3 are examples of strong electrolytes. A few salts (CdI2) and a few acids and bases (acetic acid, ammonia) are weak electrolytes. These substances are only partially dissociated into ions when dissolved in water. Non-electrolytes do not dissociate much at all. Toluene is a non-electrolyte, for example. For your project, I would suggest salt water.
water
saltwater - saturated
mt. dew
beer
apple juice
asprin water
alka seltzer water
tums water
milk
windex/with vinegar
and just about ever combonation of these.....still nothing Mt Dew was the only thing to trip my ohm meter, but not nearly enough to run anything.
In order for an electric current to be conducted, some charged mobile carriers such as free electrons (as in a metal) or free ions must be present. A solution which contains ions will conduct electricity. A strong electrolyte contains a large number of ions and will cause the lamp to glow brightly. A weak electrolyte produces fewer ions and will cause the lamp to glow dimly. A non-electrolyte has very few ions; the lamp bulb will not glow.
Strong electrolytes are thought to dissociate completely into ions. Most salts such as NaCl, and some acids such as HCl and HNO3 are examples of strong electrolytes. A few salts (CdI2) and a few acids and bases (acetic acid, ammonia) are weak electrolytes. These substances are only partially dissociated into ions when dissolved in water. Non-electrolytes do not dissociate much at all. Toluene is a non-electrolyte, for example.
To sustain a direct current, some electrode process of oxidation or reduction must occur
With that being said, if you place alot of salt in water, heat it up so that the salt becomes molten. Then place the wires from a light bulb in the water along with the wires from a battery, the light bulb will light up.
