99 E350 5.4 PI engine compatability
The engine itself is a straight drop-in, physically anyway. The intake and exhaust manifolds will be different between the PI and non-PI head versions. Most sensors will transfer unless they're specific to the year of the engine you install.
I've used a Ford reman'd engine and it was ordered for the chassis. I could have swapped everything over from the original engine but Ford's warranty pretty much demands a new intake so it was ordered at the same time. Everything else should transfer without issue.
If you're going with a scrap yard engine you'll probably have a tough time finding something that's a straight swap.
You should also post this same question in the V8 Modular Motor sub-forum---these same issues have probably been addressed by owners of the F-Series. Do be aware a lot of F-Series will be the 3-valve engines which are discussed quite a bit there.
HTH
HTH
